By what you have stated, it sounds like a lid switch failure. The lid switch has to be closed for the drain and spin cycle on your washer. If the lid switch is faulty, it will act as if the lid is not closed. On this model, make sure the lid hinge screws are tight. If the screws are loose, the hinge might not activate the lid switch.
A quick check you can do is to jump the lid switch and see if it will drain. If the washer operates, the lid switch needs to be replaced.
To jump the lid switch you need to unplug the washer and open the console. I have provided you with the instructions for opening the console below. Once you have the console open, locate the connector for the lid switch. Place an insulated jumper between the gray and tan wires. Not the green it is a ground and will cause a short. After inserting the jumper make sure it will not touch anything metal, plug the washer in. Start the washer in a drain cycle. If the washer drains and spins, you need to replace the lid switch. Do not leave the jumper in while you are waiting for the part. The jumper is only of the test.
To you replace the lid switch you have to remove the cabinet of the washer. The instructions for that are also in the image below. Once the cabinet is removed you can take the screws out securing the lid switch and remove the harness from the clips along the underside of the cabinet. Then reinstall the lid switch in the reverse order. Before you reassemble the cabinet, please read the instructions for installing the cabinet provided in the image.
I hope this is helpful. Please reply below if you need further assistance.
SOURCE: HE4t Kenmore Elite Washer - timer doesn't work
Just call on line. Sears for the benefit of your washer
SOURCE: Kenmore Series 70 won't spin
Sounds like you have got a basket drive and sub-pack issue. These are very hard to change out because it requires you to remove the inner basket, motor, transmission, agitator, pump, etc. The part number for these are:
Clutch Kit (Sub-Pack): 285785
Basket Drive/Spin Tube: 285792
If you think your up to the task, let me know and will send you some general info on getting the stuff in and out. Good Luck!!!!
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
SOURCE: Kenmore elite washer problem
my kenmore elite finish washing my clothes, but when i open the door the washer didnt rinse and drain the water. i try to put it to rinse and drain again, but continue with the same problem...
the washer beeps when the clothe its done but when i open the door didnt rinse and drain the water all the water still there.
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
