HP Pavilion dv9000z Notebook Logo
Posted on Oct 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp dv9000 will not turn on the blue lights come on and goes off right away. I bought a new cord and adapter and it does the same thing. I did try taking the battery out and holding power button for 30 sec and then just putting in power cord there was still no luck then I proceed to put battery back and no luck Please advise Thanks
goneforever.
Level 3:
Top Expert:
  • HP Master 14,531 Answers
  • Posted on Oct 30, 2017
goneforever.
HP Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263765
Points
66315
Vast posts here on black screens of deathh
the screen is 100% black and never once shows text or that HP logo. 100% dead black, then that is the screen back lamps dead
as most long ago did, go dead , just not yours.
called the CCFL lamps dead.
ok the battery out test1
the other check is the fan is the fan blowing, it must or the CPU overheats fast and (it shuts itself off, like magic (intel inside)
see slide show here for Laptop link packup causes.overheated
http://www.pcdied.com/overheated.html
my guess is it is there, below... as all do every one at 20k hours.
see flash light test. there. on test one, do that.?
see test #1 (battery out, ac pack connected and working)
http://pcdied.com/black-screen.html#Basic-basics-101
if the flash sight trick passes, (see data) ask how to fix that
or read the service manual at HP.
see the list of HP , with CCFL here. dv9000 is it.
http://pcdied.com/monitors.html
if yes, ccfl dead
see here
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xdv-9000+ccfl.TRS0&_nkw=dv-9000+ccfl&_sacat=0
1% fail this way for inverter bad, 1 in 100.
see same page above for inverters sold the lamps run of it and it makes 500 to 1000vdc to do that,, HV inverter.
5 Related Answers
Anonymous
  • Posted on Dec 23, 2008
SOURCE: hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Anonymous
  • 33 Answers
  • Posted on Mar 25, 2009
SOURCE: HP Pavilion dv4000 battery won't charge
all you really need to do to find out if it might be broken is to check and see if that DC Jack on the computer is "wiggling" around, if the center part is moving around. If it is, then there is a chance that it is broken. I used to work at a computer store where the owner would resolder new DC power Jacks into laptops, but he was the only one in town who did that. So you might want to check around at the local computer repair or electronics stores to see if someone does that type of thing. Also, have the power supply checked out, it could just be dead.
moralt
  • 145 Answers
  • Posted on May 15, 2009
SOURCE: Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
Anonymous
  • 175 Answers
  • Posted on Jul 08, 2009
SOURCE: My compaq laptop doesn't turn on
At the bottom of the laptop, find and open the placing of RAM. Unplug each RAM from its bank, clean each RAM and also its bank, Plug them again in different bank. Lock your placing, now check.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread the results of your work.
Regards;
Hassan
Anonymous
  • 6 Answers
  • Posted on Jul 16, 2009
SOURCE: dv9000 won't power on or charge. blue lightning bolt flashes
I just had this problem with my HP Pavilion dv9005us Notebook PC, and the problem is one of two things (that I know).
  1. Your'e Laptop's battery is completely empty, and needs to be plugged in to charge for an hour or two
  2. Or your laptop cord is broken, or isn't working properly.
For me, it was the secon problem. I went online searching for answers as to where I could buy a new cord for my Laptop. My previous one was universal, as the one that came with the notbook was chewed by my puppy. So Staples Canada, (or US) and Futureshop where the only places I could but this cord. They had the laptops on one wall, and the cords underneath them. In total, I paid $112.00, $89.99 plus tax, and $10 for an extended 2 year unlimited warranty. It sucked forking out the money, but I knew that I could trust the HP brand, and now have a working laptop.
Hope this helped (:
-Hannah
I have an HP Pavillion dv9000 the blue lights come on for just a sec and then nothing. It will turn on periodically and works great when it on. But that is the problem it hardly ever does. Just the blue...
This could be lots of things. so lets try the easiest.
Blow out the dust in and around the fan(s)
replace the AC power cord and/or battery.
replace hard drive
and the big one replace Motherboard (which i done once in my lifetime)*
* = most likely not it.
I have a CLT2054 and lost the power cord. I bought a new power cord but when I plug it in the light on cord goes out and TV wont come on. If I un plug cord light comes back on
You have short circuits inside the TV, the AC goes into shutdown when it senses too much current being draw. Post some pictures inside the TV if you can, wee need to look for short circuits, another thing, you bought new AC adapter with the same voltage and current rating, right?
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
1helpful
HI, My Hp DV9000 will turn on but shuts off the
There could be a few possibilities here, first the ac adapter needs to be checked for voltage at the tip, it has to be between 18.5 and 19.5 volts. The battery is most likely dead or has dead cells which will not carry a charge. The third problem could be the motherboard. Try leaving the battery out and just run the laptop off the AC adapter....if the laptop runs fine , then the battery is bad and sending signals to the motherboard causing a shutdown. If the laptop is still shutting down or refusing to start, then there maybe a problem with the voltage resulator in the charger brick. If the battery and charging brick are in good condition, then the laptop may be getting a thermal shut down signal from the processor because of an overheating condition. The processor heats up immediately, if the laptop has been run overheating for some time, the thermal grease on the processor can be cooked off reducing the efficiency of heat bleed off, thus causing a shut down to protect the laptop from a terminal meltdown. Try using compressed air and blow out all the ventilation grills and compartment openings to clear out debris, hair and dust.
Presario C700 won't turn on after installing new screen
Why was machine taken apart? Did you check memory to make sure it's sitting correctly?
2answers
4helpful
Dv9000 won't power on or charge. blue lightning bolt flashes
Hope this helped (:
-Hannah
Hp dv9000 will not start up. blue lights are go
HP Compaq plugged in & blue light on but icon says NOT plugged in
Check power out put of the adapter is it giving you the correct readings
Try to remove the battery and run it from adapter itself check to see if its working
Reset the battery ..by removing it from the system
2answers
HP DV9000
The link you are referring to I have been posting to people for severa months as there are problems with several compaq and HP
HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario v3000/v6000 Series Notebook PCs - HP Limited Warranty Service Enhancement
LINK
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
