Belkin (F5D5231-4) Router Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost router password - Belkin (F5D5231-4) Router
Anonymous
Level 2:
  • Expert 298 Answers
  • Posted on Dec 17, 2010
Anonymous
Expert
Level 2:
Answers
298
Questions
Helped
122992
Points
871
Hi there, the best solution for you is to reset the password. Hold the reset button for at least 5 seconds.
Then access the HTTP portal and use these:
Username: N/A Password: (blank)
Hope this helps,
levibit
2answers
Lost my wifi password
Hi, buddy. If you have lost your wifi password in your android phone, you can watch this video and try the app to recover your wifi password.
It's very easy to recover your lost wifi password. Hope you like my advice.
We lost our password. Wanting to reset the password
A forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router. ....read more to reset password
1helpful
I lost my pass word that came with router.
If you lost default password,then you can search online using the model no and brand of the router. From router manufacturer website ,you will get the default login details.
Lock my router
You can reset you router to it's factory default settings:
Have you somehow lost your D-Link router's password? Perhaps the easiest way to gain access to your router's admin interface is by restoring it to the default factory settings, however, if that is not possible, try method number two via the master password. If you lost your WEP password, visit this post for more info - Recover Lost WEP Wireless Network Password Key.
I hope this information will be helpful. Thank you for using FixYa!
7helpful
2answers
I lost my net gear n150 cd and i want to change my password..
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
1helpful
Lost password to router
Reset your router and the password should be reset.
1helpful
2answers
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
How to recover a lost password on a Nortel SR 1004
There's no way that you can restore a lost password of your router. The only way you can do is to reset it to factory default and you must know the default username and password of your router. Some of the router manufacturers uses: admin for username and pass for password, some just leaves the password blank but put admin for the username.
2helpful
2answers
Cant get router settings due to lost user name and password need to open ports
There should be a recessed button on the back of the router that you need a paper clip or something similar to access. Press that button down for about 20 seconds and it will reset the router to default settings. Then use the default login/pw to reconfigure it. There is no way to recover a lost password from a router. If you know the exact model of the router, you can download the user manual from dlink's website.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
