Did you eliminate the simple and obvious first? Change the cables and the devices you are connecting to the television to see if they are at fault to rule out faulty cables and/or a faulty signal source. If the device connected to the television is not the problem and the cables connecting the device to the television are not the problem you will need to engage the local repair shop to complete the soldering for you.
Change tv to another incomming broadcasting cable or put another tv to that incomming signal,see if this is the causes of by the incomming broadcast signal?If the incomming broadcasting signal cable is good.U have tools like a soldering iron,a role of solders,aslo can u do basic soldering?Yes.Take the tv aparts,resolder the video board that connected CRT socket holes.On the CRT inter neck have R,G,B,Y connected to the main board,resolders that wires connections R,G,B,Y to the main board.This shold solved ur red color gun missing.
I have no clue how to do this. I do not have soldering tools nor do I know how to take the TV apart.
I do not understand the solution I have been given. I do not have a soldering tool nor would I know how to use one. I cannot get my TV to show reds at all. Do you have a solution I could understand?
Well, I don't know if it is or not but I'm going to accept it because I'm not willing to take it in for repairs since it is too old to spend any money on. We are planning on getting a new TV after the holidays. I was just hoping for a quick fix to get us thru to Januray.
