You said "Open up the front of the set by removing the speaker screen and the black piece of particle board". How do I do this? I can't figure out how to remove the speaker screen etc. Thanks
At the bottom of the speaker grill there are two holes filled with a plastic plug. Use a small flat head screw driver on the sides of the plug to slide the plugs out. You'll see the little space next to the plug on either side that you can put the flat head in to slide the plug out. Once you do that there are screws behind those plugs. You'll need a phillips head to take those out. Then just pull out gently at the bottom of the speaker grill and it should come toward you then just slide it down a little and it comes right off. Behind that is the particle board screwed on in the center with several screws. Take that off and you can't miss the adjustment blok.
