SOURCE: 4 inch thick black vertical line down the middle of the screen
Hello JayZ,
Let me explain whats going on here. Your lite engine (inside the TV which shows the light) has a part called the lite tunnel. They use a special glue to put four rectangular glass together to make a small tunnel. This glue falls apart inside and cause a shadow. This can be fix by replacing the lite tunnel which cost a few dollars. or you can replace the entire lite engine which cost over $1000. This is covered by the manufacture because your set is still under warranty. Samsung would rather replace the lite tunnel because its cheaper for them. The problem with replacing the lite tunnel is that it takes a special trained tech to do that. If the part is not installed correctly you may end up with a tilt picture or top of the picture is mis aligned.
Best regards
circuitcity
SOURCE: white spots on screen and growing every day
If these spots are small, they are likely the visual effect of a failing DLP chip. When some of the tiny mirrored surfaces on the chip stop moving, this is the result. This is not something you can fix yourself. A Samsung authorized service center will charge $400-$500 to replace it for you.
michtech
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
SOURCE: Was watching TV and the picture just went black (still had sound)
eithor the flyback just craped out or the tube went
try turning up the flyback failing that call a service tech and ask for a quote
quote cose 30-50 bucks
atleast you will know forsurre if it's worth fixing
SOURCE: Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
www.discount-merchant.com
Good Luck and besta regards
Ness
