Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Dec 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool wfw8500sr01 door locks and does not start F24 f26 f28 error codes
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Mar 04, 2011
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5037058
Points
35540
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa&^%
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Whirlpool f28 error code and door lock light
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is a link to the CCU.
Here is a link to the MCU.
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
13helpful
3answers
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • 1helpful
    F35 code
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    To remove the error display, press Pause/Cancel twice.
    Take care
    F28 continues to show on display.
    Comunication error between motor control unit and Central control unit. Broken wire in the harness.
    F01 power glitch: disconnect power for 2 mins verify correct CCU operation
    F11 Motor control unit internal failure MCU board failure or broken wire.
    F20 No water detected entering machine, pressure switch hose clogged
    F21 Long drain Possible cause: Clogged filter, clogged/failed pump
    F22 Door lock error Failed lock. corrosion,or broken wires.
    F23 Heater Failure Bad heater
    F24 Water temp sensor error Failed sensor or heater
    F25 Motor Tach error Bad MCU (motor control unit) or broken wire
    F26 Door switch error Door not opened after 3 cycles. Note: suds errors cause the machine to try 3 times to fix a problem with wrong detergent too much detergent , and this error could be associated with that, my opinion
    F27 Overflow condition Clogged drain, pump, kinked hose.
    F28 Com error between MCU and CCU (central control unit) Broken wire
    F29 Door unlock error bad switch,broken wire,corrosion
    F30 Dispenser system error Bad or jammed motor, broken wire
    F31 MCU failure due to motor overheating.
    F33 Pump drive system error, broken wire, corrosion
    rL (prewash)Clothes detect. Remove clothes and retry.
    5d Suds lock detergent overdose(hay I ain't making this up, too much detergent, the wrong stuff, added to the wrong compartment, etc
    The technicial data sheet along with that pesky clogged pump is located behind the toe kick panel; remove the screws under the bottom front edge of the washer. Tip the appliance back to get to them screws. With the screws removed, the panel will comes down and off.
    For diagnostics and further info refer to this handy dandy:
    DUET SERVICE MANUAL My tip:
    http://www.fixya.com/support/r4232744-duet_sport_washer_error_codes
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    3helpful
    Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
    f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
    1helpful
    ERROR CODE F71
    8helpful
    Whirlpool duet wahsher
    PLACEHOLDER FOR ART
    NOTE: If the error remains on the display, then call for service.
    please do not forget to rate and comment about your experience with fixya today.
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
