Question about 3DO Heroes of Might and Magic 4 for Windows
Im trying ti install heroes 4 and it say I need 128mb of memory... i have 2 gb of memory and says it fails to meet requirements...should i look for a patch? Im using windows 7. thx for ur help
    Sergeant:
  • 161 Answers
Your using Windows OS 7, which is fairly new. This is great for programs but not for games. Heroes 4 is a older game, so there are some compadablility problems.
As for your memory and HD space you should be fine since the requirements are low.
Solutions: Look for programs which allows you to run virtual OS of pervious generations of windows (such as windows xp). This should solve your problem. Otherwise if you have 2 HDD on your laptop/computer you can make one drive into a older OS. Then run the game from that HD.
Good luck, and rate my response.
Posted on Dec 15, 2010
Anonymous
SOURCE:
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
Can windows 7 run GTA IV.
Running GTA 4 on windows 7 should not be a problem. You just have to run the installer using compatibility mode. Right click on the "setup.exe" then choose Properties. Go to Compatibility tab and tick "run this program in compatibility mode for", choose windows xp sp 3. That should allow you to install GTA 4 on windows 7. Bear in mind that you have to install GfW Live and the C++ 2005 files seperately which can be found in the disk as well. More importantly, make sure that your computer meets the system requirements for the game.
Here it is: System Requirements
Minimum System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3 Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz Memory: 1.5GB, 16GB Free Hard Drive Space Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3 Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista) 18 GB Free Hard Drive Space Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
After installing the game and you're not able to run it, Try running the main executable file of the game in compatibility mode as well.
Hope this helps.
Apr 21, 2011 | Rockstar Games GTA IV
I am upgrading to windows 7. How much memory should go with the up grade? at present time I have1028 and512 GB installed. CPU ok for the up grade?
minimum 2GB for smooth use of the pc, but RAM is fairly cheep so I would go for 4GB. The most importet hardware to be fast is your harddrive.
Mar 26, 2011 | EliteGroup KM400-M2 Motherboard
I recently picked up an older game, Heroes of Might and Magic IV get home and install. Install wizard runs fine except for one thing despite the fact it correctly identifies all my hardware, it tells me...
I have Heroes of Might and Magic 5 Running on Win 7. There were many patches to install before this title worked(on my computer). Have you installed all the available updates for it?
Here are 2 sites that have the compatibility options:
http://techpaul.wordpress.com/2009/06/28/compatibility-tricks-for-old-programs-new-machines/
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
If that does not work, you can also try to set up XP mode in Win 7: (Note: you need to have Win 7 Pro, Enterprise, or Ultimate for this one) Win 7 Home Premium does not support XP Mode.
http://arstechnica.com/microsoft/reviews/2010/01/windows-xp-mode.ars/
Jan 29, 2011 | 3DO Heroes of Might and Magic 4 for...
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
Cannot install final cut pro.....the software says my macbook pro(macbook3,1) does not have minimum system requirements. my mac.... 2.2 ghz 800mhz core 2 duo 4gb ram 2x2gb @ 667mhz GeForce 5600m gt 128mb...
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry.
ken
Apr 04, 2010 | Apple MacBook Pro Laptop Computer with...
Can windows 7 be installed on asus k8v-mx mb with amd sempron 2.4 1gb ddr1ram
this is the minimum spec for Windows 7:
  • Processor: 1 GHz 32-bit or 64-bit processor
  • Memory: 1 GB of system memory
  • Hard drive: 16 GB of available disk space
  • Video card: Support for DirectX 9 graphics with 128MB memory (in order to enable Aero theme)
  • Drive: DVD-R/W drive
  • Internet connection (to download the Beta and get updates)
Its not the motherboard, its the processor speed, RAM size, and hard drive space, and video card capability that counts.Your processor speed well meets this criteria and also your RAM size is within spec for Windows 7, and im sure you will have in excess of 16GiG hard drive space. So its all down to your video card. You may need to install DirectX 9.Hope this helps :)
Feb 14, 2010 | ASUS K8V-MX Motherboard
Will the Aspire 5100 run Windows 7?
if your laptop meet the requirements of windows 7 it is good>>. it can run the windows 7>>> i will give you the system requirements of windows 7>>>>
Dec 14, 2009 | Acer Aspire 5100-3357 Notebook
I cant play on my pc for some reason it says "oblivion has encountered a problem and needs to close" why is this?
It is usuall one of a few reasons:
  1. Your system may not meet their minimum standards.
  • Minimum System Requirements:
    • Windows XP, Windows 2000, Windows XP 64-bit
    • 512MB System RAM
    • 2 Ghz Intel Pentium 4 or equivalent processor
    • 128MB Direct3D compatible video card
    • and DirectX 9.0 compatible driver;
    • 8x DVD-ROM drive
    • 4.6 GB free hard disk space
    • DirectX 9.0c (included)
    • DirectX 8.1 compatible sound card
    • Keyboard, Mouse
  1. You need to update the game or download a patch.
  1. You may need to scan your computer real good for a virus.
If all else false un-install it and re-install it. let me know if these help you.
Sep 09, 2009 | Bethesda Softworks The Elder Scrolls IV:...
Minimum Requirements
It appears the game doesn't support your memory!??
Never heard of that before...
You should check for new mainboard drivers, or maybe the memery isn't correctly inserted on the pins on your mainboard.
If that's not it, you should probably reinstall your PC. Probably a little error in some Windows library that can't be solved by rebooting...
I suppose you can play other games on that PC, right?
Good luck,
Yannick
Oct 17, 2008 | 3DO Heroes of Might and Magic 4 for...
3DO Heroes of Might and Magic 4 for Windows Logo
1,686 people viewed this question
Top 3DO Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a 3DO Video Game Console and Game Expert? Answer questions, earn points and help others
