Try this link:
Sylvania 7 Smart Book How to connect to WIFI
Is this a windows notebook? How did u install the drivers?
SOURCE: just purchased the Synet07526 sylvania
i am having exactly the same problem and am very frustrated with it! can't get tech support on the phone and they are not calling back either!!!
Hi! Please try this. Remove the battery and press hold the power button for 10secs. while the battery is removed, this should reset the system and may resolve the problem. Put the battery again, turn it on and see how it goes. HOpe this helps and thank you for using FixYa!
SOURCE: Can't get my Sylvania 7" netbook to connect to
If you think you may have an incorrect ip address, that probably means you changed it by setting a static address. Most systems (with the exception of business systems using domains), use auto ip addressing. Logging on to most wifi hotspots and most home wireless routers requires auto ip addressing. To set yours to auto (this is with XP, I think Vista and Windows 7 is similiar, you just find the controls in slightly different places) go to Control Panel, then to network connections, then right click on the 1394 connection and select properties. In the new pop-up box, if it is not already selected, select tcp/ip and then click properties. (You can also double click the tcp/ip item). In the new pop-up box, make sure both "obtain ip address automatically" and "obtain dns server automatically" are both selected by using the radio buttons. Click Ok on both pop-up boxes to close. While you're in the area, the control panel should still be open. Double click "internet options." Then click on the connections tab, and towards the bottom, click on the lan button. On the new pop-up box, uncheck automatically detect settings. This usually makes you wired connection faster.
SOURCE: trying to get my sylvania 7 inch netbook to bring
I used a router and adjusted the same conf. for both the router and the net book. All you need to do is to match both. I also know that you need to activate the wi fi by pressing the fn f9 buttons at the sometime. Try to log on and if it says connected but you are not able to use the net go to internet options and type yahoo.com or goggle.com. If you still not able to connect shut down and log on again. It works. Hope this helps Mrs.Mo
