Check if there is any dew condensation to trigger a shut down. Use a dryer to warm up slightly and test.
If not the main board can be faulty as the CCD imager is not functioning.
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
Required software cd for GZ-MS230UB is available in JVC Accessories Store for $35 under following part number: LY37342-002A-S ... CD ROM ASSY Click above link for more details and online order. Thanks.
I answered same problem like you have now. Just in case you don't find it. I hope you are familiar with these things technically. Open the set up-to where the lens can be accessed, remove the iris unit and clean those two curtain(shutter), for sure it's stucked up. You san test it by moving it open manually and it must close when released. To clean, you have to remove these curtain out from the assy. Spray with head cleaning agent or any alcohol base cleaner and dry.Test iris unit first to make sure its ok before assembling. Good Luck
