Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
I dropped my camera in my drink. Canon SD 1300. I pulled it out immediately but now it says lens error. will restart automatically. the lens is out and will not go back in.
    New Friend:
  • 116 Answers
That is a problem you will need to go to fix at a Canon store or local camera store. It shouldn't cost more than $20.
Posted on Jun 26, 2011
6ya staff
SOURCE:
Canon sd 1300 lens error
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 22, 2013 | Canon Cameras
Canon power shot SD 1300 IS says" lens error" will shut down automatically
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 10, 2011 | Canon PowerShot A560 Digital Camera
I was taking photos when suddenly my Canon PowerShot SD 1300 IS IXUS 105 read "Lens error. Will shut down automatically. Restart camera." Then the screen went blank. The lens will not retract....
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bad. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. You can send it into Canon and get it repair for a flat rate. Sorry about your camera.
May 25, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My camera canon power shot sd 1300 is dont work it say error reset automaticalli
You could be having a power problem, or lens issue. The following blogs discuss things you can try to get the camera working:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
and:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If nothing helps, contact a local camera shop to get an estimate for repair, or contact Canon support:
http://www.usa.canon.com/cusa/consumer/standard_display/support
Good luck, and hope this helps.
Mar 01, 2011 | Cameras
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Apr 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon sd 600
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 04, 2008 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
118 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
