Programming When Key(s) added or replaced. System malfunction. How Obtain all keys fitted with remote control. Fasten seat belts and close all doors. Turn ignition switch from position I to position II 4 times within 6 seconds. Turn ignition switch to position I ( 11/2000). Switch ignition OFF (12/2000 ). Programming mode activated for 10 seconds proceed as follows: Press and hold lock, unlock or boot release button Fig. 1 [1], [2] or [3]. Wait for acoustic signal (indicates correct programming). Repeat above procedure within 10 seconds to program remaining keys. To exit programming mode: Turn ignition switch to position III or wait 10 seconds. Keys can also be programmed using diagnostic equipment.
When you try to use the DVR features, do you get an error message (024 or 311)? Have
you unplugged your 625 receiver yet? If not, unplugged the receiver
for about 10 seconds and plug back in. This will cause the receiver to
reboot and acquire satellite signal. When the picture comes back on,
try to pause. If it still doesn't work, we may need to replace the 625
receiver. I hope this helps.
Setting DELAY for All Search Ranges
You can set the scanner to have a delay after the end of a transmission before searching
resumes. This slows searching, but helps you prevent missing replies on a frequency.
1:SERVICE OPTION → :CHAIN SEARCH → 3:DELAY
1:NONE
The delay is turned off.
2:1 SECOND
The delay time is 1 second.
3:2 SECONDS
The delay time is 2 seconds.
4:4 SECONDS
The delay time is 4 seconds.
28
5:INFINITE
When the scanner stops on a transmission, you must press RSM to resume
searching.
6: -2 SECONDS
The scanner only stops on transmissions for 2 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 2-second pause.
7: -5 SECONDS
The scanner only stops on transmissions for 5 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 5-second pause.
8: -10 SECONDS
The scanner only stops on transmissions for 10 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 10-second pause.
You mean it hangs up at pause mode and you can't turn off you device? if so, push up/press power button and hold for 10 to 20 seconds until the device turn off.
Then, turn on. if it' working. You should update new firmware.
Good luck
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
Control Lock
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
Hey hpnotiq_babe, Directions on how to set the self timer on this camera are on page 27 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I have copied the instructions on how to set the self timer on your camera below. I hope this helps! ● Selecting the self-timer 1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode. 2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor. A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work. •2SEC self-timer ( ) : Pressing the shutter button will allow an interval of 2 seconds before the image is taken. •10SEC self-timer ( ) : Pressing the shutter button will allow an interval of 10 seconds before the image is taken. •Double self-timer ( ) : A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time. 3. When you press the SHUTTER button, the picture will be taken after the specified time has elapsed. http://www.samsungcamera.com/customer/cus_main.asp?cat_uid=11 Sincerely, Allan Go Ahead. Use Us.
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
•2SEC self-timer (icon of incomplete circle with 2S) : Pressing the shutter button will allow an interval of 2 seconds before the image is taken.
•10SEC self-timer (incomplete circle) : Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle) : A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time. 3. When you press the SHUTTER button, the picture will be taken after the specified time has elapsed.
Apparently your TV doesn't support the progressive mode (480p).
You should be able to turn it off by pressing the pause button on the recorder for about 5 seconds, untill it turns off I guess.
Hope it works
