TV is 3 years old....after turning TV on...TV goes off...and won't stay on!!!
Help me!
SYMPTOM:
Clicks and turns off after turning on set when cold. Have to turn on
and off several times to work, or keep changing channels, right side of
screen is black for a while.
PROBLEM: It is almost always a bad transistor and a bad capacitor. (about $0.70 in parts)
SOLUTION:
This repair is fairly straightforward. You will need a soldering iron,
a solder ******, and a small torx bit. Unplug the set. Lay the TV on
the floor, screen down. Remove the torx screws holding the rear cover
on. There should be 10, (don’t forget the 2 by the input panel). You
will see 2 circuit boards, the one of interest is the large one near
the bottom of the set. This board has a retainer clip on each side that
needs to be pulled out to allow the circuit board to slide out. Slide
the board out about 5-6 inches. You might need to support the board so
it doesn’t slide back down into the TV set. This circuit board should
have numbers by each of the components. You want to look for 7461
(transistor) and 2455 (capacitor). They are located right next to each
other near the center of the board. The transistor will usually
overheat and discolor the circuit board immediately around it. Warm up
the soldering iron and get the solder ****** ready. Heat up the solder
joint while removing excess solder with the ******. Once the transistor
and capacitor are free, check the numbers on each. The capacitor (round
cylinder) should have “47uf” on it. The transistor should have “C33725”
on it. You can order these parts from Digi-Key (google it) for about
$2.50 including shipping if you use USPS option. The part numbers are:
493-1060-ND for the capacitor and BC33725-ND for the transistor. Once
you get your parts, solder them in and check TV operation. It should
work as it did before. This
repair can be done by anyone familiar with a soldering iron in about
30-45 minutes their first time. Good Luck!!
-Courtesy of jack of all trades on howtomendit.com.
The same tv as well and it goes on then a few seconds later the picture goes off. It has to be a defect in this model. We should contact the mfg.
Please help me
Solution #6 is the right solution. I did this repair. I'll share some stuff he left out. If you can still get the TV to work, and it's not at complete failure, the capacitor at 2455 is the only thing that needs to be replaced.
I got the capacitor at Radio Shack, and they still sell them. You want a radial lead 47microfard or 47uf 35v polarized capacitor. The one I bought was mostly blue with a thin black strip in line with one of the leads. I'm not electrical in anyway so I spend a lot of time trying to figure out what this meant.
The capacitor in the TV was mostly black with a grey strip. I oriented my mostly blue one so that it's black stip was in line with the existing one's grey strip during replacement.
It was $1.49 in parts and less than a penny in solder. The hardest part was removing all the screws. You need an allen wrench to do do it.
Excellent addition with insight for this problem. I am an "old" techie, and I would have just ordered the transistor and the capacitor on-line, then worked on this problem sometime in the future when my parts arrive and I have another day off. Because of your insight on just replacing the capacitor, I took my TV apart again and found a new capacitor in a box of misc. parts I had on a shelf in my basement. Since I just finished taking my TV apart to "look it over" and reseat the connections, it was easy for me to dive into it a second time before I put it back on my TV table and suffer through taking 10 or more minutes for the picture to stay on.
Thank you very much!
I have same exact TV with same exact problem..TV is less than 3 yrs old .anybody find out the solution?
Same tv same problem bought it in 2004/2005 been working fine till now
Hello there, I'm having a major problem with my TV, I have called all of the local TV repair shops and they all are the same, they want money money money before they will even speak with me about the problem I'm having. This is the only TV in my entire household for a family of 4 and we desperately need the TV in working condition for our kids. I don't want to have to put out $500 for another set if I don't absolutely have to.
The Problem...
About 3-4 months ago the TV when turned on, the picture would slowly come into view and be very scrambled and before the picture would come into complete view the TV power would shut itself off, but the power light would remain on. You can hear the "Click" noise when it would shut itself off.
2-3 seconds after it 'shut itself off' then the TV would make the "Click" noise (The same noise it makes when you first turn it on), it would make the "Click" noise over and over and over again but nothing would happen. So i would turn it off and on again and change the channel rapidly until after 2-3 minutes it would come into view and work.
So we decided to leave the TV on 24 hours a day. Then today we awoke and it was off and making the "clicking" noise over and over and over again but with no picture or sound. Now it wont even turn on/off it just sits there and goes "Click, Click Click Click" and doesn't do anything.
I described the problem as best as I can. Here is the TV information and specifications...
Philips 27 Inch Tube TV
Model Number... 27PT54 3S37A
Serial Number... 78438404
105 Watts
60HZ
120V
Date Code March 2003
Now that I typed the model number there are threads everywhere people saying the same issue exactly as me, I will read them but please someone tell me is there anything I can do...
Can anyone explain exactly what is wrong with the Tv and why it's doing this?
Also, what should I expect to pay to repair it?
Any information or help would be appreciated very much.
Thanks in advance,
Anthony
This is utterly horrible, I see the same exact problem with a bunch of people with the same TV and Philps is junk. I will never buy anything Philips again.
Their is 2 capacitors that need to replaced 2.2uf 100v and 47uf 50v both will be right behind the FBT flyback Transfomer
Replace 2 capacitors 2.2uf 100v and 47uf 50v. located behind FBT flyback Transfomer
I have the same tv as well and it goes on then a few seconds later the picture goes off. It has to be a defect in this model. We should contact the mfg.
I have a philips tv and suddenly one day by mistake i turned on the security level from low to high from settings. i dont have the service remote so what will i do? please hlp me out
THE SIMPLE ANSWER:
I have the same tv... bought about 4 years ago Phillips 27" Tube Tv. When I turn it on after it has been off for a while it comes on for about 3-15 seconds and then shuts off.
SOLUTION:
To keep your TV on and running just start surfing throught the channels. Sometimes I only have to change the channel 10 times and it will stay on for good. Sometimes I have to go through 50 channels to get it to stay on... I am going to be smashing this TV into small pieces very soon. LOL if only I could still buy a picture tube tv, nowadays its LCD or nothing...
Well, this issue with the TV became progressively worse, and now it is residing in the junkyard.
Same problem! it's driving me nuts!!!
Ditto - exact same problem - probably the same model tv as well. great, huh? mine was a xmas gift...philips should definately recall these.
picture goes out. You have to keep clicking channels up and/or down and finally it will show up.
tv keeps goin off
I have a dvd vcr combo. It keeps going off when you turn the tv on.
Same TV same problem.
I have the same tv as well and it goes on then a few seconds later the picture goes off. It has to be a defect in this model. Philips model 27pt543s37a
have the same problem model#27PT543S37A... 32"
turn tv on.. few seconds and picture goes out, but green power light stays on.. just does it over and over... only 3 yrs old. as of 8/2008, says it was assembled in 4/2005.. never buying anything philips again...
I have the same TV and same problem, which started yesterday. I have had this set for 7 years
I have the same problem with the same tv and same model.. Does anyone find the solution ??
Well, I might as well join the crowd, I have a Phillips TV about 4 years old, and when turned on, it will stay on for a few seconds/minutes and then shut itself off. The click noise is heard, and the red power on button is still glowing. I would buy another Phillips TV after what I paid for this hunk of junk. The only thing we can do is keep on using the remote to turn it back on.
I also have the same problem. Only mine is a 32" 32PT563S37G
Oct. 2003 model. It's the newest most expensive TV in the house and the only one that doesn't work. So flustering. I hope someone can come up with a soulition.
I have the same problem and I've only had the tv for 5 years. Very frustrating...
