SOURCE: Problem in closing window of any internet explorer screen with Windows Vista Home Premium
I would recommend you to back all your work up, then with the use of the restore cds, re-build your laptop. Then see if you get the same problem. If you do, then you need to send the laptop back
SOURCE: Hello iam using hp printer
I believe I had the same problem at one time. Just by memory---I think I had to disconnect whole printer from power source--let sit about 10 minutes and then when I started back up---it took forever to reset, but then worked.
If that doens't do it, try to read the troubleshooting in the manual or do more research via online. But I believe I figured that out via the printer website under troubleshooting or FAQ.
SOURCE: NEED SOUND DRIVER FOR HP PAVILION DV 1000
log on to the link below and download, its free
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=435618
SOURCE: sata drivers
google sata drivers, abut this is not all you are going to have to do.
You might first check to see if ide is active in the bios.
