I am not familiar with this particular lighter, however, changing flints isn't usually difficult. Could you post a photo of the underside of the lighter? Try turning the lighter upside down. There should be two sections moulded in the bottom of the lighter. One is the refill port you use to fill it with gas, the other will be the adjuster or mount for the flint. The flint holder is usually a Spring loaded tube with the flint mounted at the top end. Carefully unwind the screw or twist cap being careful the spring doesn't suddenly release. This should slide out letting the remains of the old flint fall out. You may need to GENTLY tap the lighter to knock out any dust left by the old flint. Insert the new flint, insert the retaining pin and screw it in until it is finger tight. Screw too tight and you could crush the new flint or damage the screw thread on the retaining pin.
I've seen spare tanks come up on eBay from time to time, for $30 - $50. If not, picking up a beat-up Cartier on the cheap just to remove and use its tank is an idea. Cartier does not sell spare parts of any kind (other than flints), so if your lighter needs a new tank they will probably insist you get a complete maintenance service, which can cost up to $300.
Sounds like the valve that regulates the gas flow is sticking in the open position even when the lighter is not in use. Try spraying a light machine oil like WD40 on the gas jet aperture and any other moving part whilst your at it. Wipe excess oil from the lighter and leave for several minutes for the oil solvents to evaporate. Light the lighter a few times in rapid succession to enable the oil to penetrate. If the oils done it's job the gas should no longer leak.
To look up the steel ligter serial number is very easy ,I specialize in buying and selling Cartier watches. I've seen fakes with
all the correct marks and a serial number, but that doesn't mean they
are legitimate. If the watch was registered by Cartier when it was sold
or if it has been sent in to Cartier for service Cartier will be able to
verify it is authentic, but be aware that if the watch was not
originally sold in North America or was not registered when sold (fairly
common) it can still be authentic. Some sellers offer the Cartier
quartz model for sale and only state that the watch has a quartz
movement, but fail to mention if it has a Cartier quartz
movement. If it has a replacement movement in it the watch is
technically authentic, but not original and is not worth as much as one
with an original or a genuine Cartier replacement movement. The biggest
mistake I've seen amateur Cartier buyers make is using the Cartier
micro-script signature on the Roman numeral to verify authenticity.
Indeed this is a good indicator, but not the best indicator as there
were many Cartier watches produced prior to the technology required to
make the micro-script possible and not all Cartier watches have Roman
numerals for the dial to have the micro-script signature. Furthermore,
the micro-script is not always located at the same place and if the dial
has been refinished it may not appear at all. Another common problem is
actually caused by language differences, i.e. "all original versus
"authentic". A watch can be authentic without being all original. Unless
someone has owned the watch since it was new and it has never left
their sight it is impossible for them to state the watch is "all
original" as a part could have been replaced at some point in time --
even without their knowledge. Your best bet is to buy from a reputable
seller even if you have to pay slightly more money. --
Cartier_Specialist
If you can't find a used reservoir tank on eBay then you'll have no choice but to have Cartier service the lighter. Nobody sells new ones other than Cartier.
The reservoir tank can be the bane of existence for a Cartier lighter owner. Unlike most butane lighters which have gas tanks integral to the lighter, Cartier utilizes a user removable tank. Cartier only warrants the tank for two years. I've also seen tanks that say 12 months. New Cartiers come with one spare tank. I've seen spare tanks come up on eBay from time to time, for $30 - $50. If not, picking up a beat-up Cartier on the cheap just to remove and use its tank is an idea. Cartier does not sell spare parts of any kind (other than flints), so if your lighter needs a new tank they will probably insist you get a complete maintenance service, which can cost up to $300.
I cant fill my cartier lighter with gas
^Try Newport butane. It has adapters on the lid for virtually every lighter
