I have two black spots that I can see on the screen-they appear in the pictures, as well. I have tried wiping off the lens, and the spots are still there.
Today, out of nowhere, when I zoom in and out, the camera is making a little noise.
AH! Help! I've only had this camera for 17 months and I take care of it!
SOURCE: Dust particle inside lens
if its dirt, then it would be better to gave it serviced by an authorized sevicer. check also if the spot blinks and if it is..............its a dead pixel.(dead pixel os not a malfunction)
its normal with all lcd screens. you may set up repair file for yet camera on www.sony.com/repair or call 1800-222-7669.
SOURCE: black spot in screen
Nice picture illustrates the problem very clearly. It seems to be out of focus and as it is recorded on your pics ( as I understand), it must be something in the optics. See if you can peer down the lens at the front of the camera to see it there is something trapped between the lenses. You may need a strong light to do this. Shake the camera (gently) to see if it moves.
Let me know how you get on.
cheers
SOURCE: Sony DSCW50 Black spots on image
Sony will replace lens assembly.
I'm not sure about qualified local camera tech will apart lens assembly to clean it.
SOURCE: A Black spot appears on screen at 4X zoom and then
there must be some fault in sensor check with the service station.
