Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
Perform a hard reset to return it back to original state.......
To perform a hard reset on a Cingular 8125, I-mate Kjam, T-mobile MDA, or other similiar device:
Hold down the communications manager button (top left) and the Voice activation button (top right).
While holding down those two buttons, use the stylus to hold in the reset button for a couple seconds.
Release the stylus but not the other two buttons. After a couple seconds, a black screen when come up asking you to press send to continue.
Release the communications manager button and the Voice activation button and press send (green phone button)
there is a very tiny reset button on the back you need a safety pin or tooth pick to push the button same thing happend to me just do that and it will be fine
try to reset ..
1) Press and HOLD power button
2) While holding power button, press in RESET button
3) While still holding power button, release RESET button
4) Continue holding power button, you should see TomTom reboot
hello,
from your opening key button, on the car key, its a black,folding key. keep the opening button pushed until a red light apears in front of the key side. then start the engine. Both lights on the inside rear view mirror will blink.
then is reset.
hope will work.
peter
Select Time reset button (right lower side) until seconds flash
Select Start button on face and cycle through until 24-HR
Select Lap/Reset
