I have an orbit auto sprinkler that can changed to a manual control, because I have not used the system for quite a while, recently I tried just to use the manual system, but I got no water come from any of its stations, at one instant, I did hear water coming out, but I could not see where the water was flowing out, I played with the controller, but no water came out anywhere. I had another system in my back yard, water master brand, I was able to its manual system. what is wrong with my orbit controller ? pls. reply. thanks.
Does it work manually? If so, which is rare and almost unheard of I would replace the timer. You can't buy a less expensive timer $20 for a 4 station. Which explains why it is not working. If it doesn't work make sure it is plugged in and outlet has power.
I am experiencing the same problem with my Orbit 57004. Did you ever figure out what was causing it not to start in "Auto" mode? he solutions above are not panning out for me.
Question is not clear. Do you have programming problem with the timer? Or problem locating sprinkler heads? Or a sprinkler valve problem? Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF. Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF. For example, when timer turns ON, then station 1 starts watering. Timer turns off, and then sprinkler valve automatically advances to station 2. Timer turns on again, and station 2 starts watering.
moved into house with 4 station Orbit sprinkler unit. Manual is faded, cannot figure out how to get it to control the sprinkler system. Can I get online instructions on how to program it?
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
