SOURCE: How to take the top off Ultimate Care II
2 screws behind control to loosen control panel. when out panel will hinge back and you should see 2 clips that will pop off with a screwdriver and harness for lid switch. whole cabinet will then come off iff you pull it forward
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
SOURCE: whirlpool ultimate care II top load skips agitation turns
I have the same problem, and i think it is a problem with the agitator i pulled mine off, (remove softener insert below that is a seal easily removed and then a 7/16'' bolt) seems a 'clutch' mechanism between base and upper agitators is shot.
