Question about Electrolux Lux 5500 Canister Vacuum
How do i open the housing of an electrolux ambassador model #c101j to fix cord recoil
  • 694 Answers
This can be a complex undertaking, so I highly recommend taking it to the nearest Aerus Electrolux store for repair. I've seen many disassembled machines come in to the shop because the owner couldn't figure out how to put it back together. Any misplaced wires during reassembly can result in nonworking vacuum, shock and even fire hazard.
Taking it to the shop may cost more, but I believe is less expensive in the long run. They'll do it right.
http://www.aerushome.com/storelocator/
Posted on Dec 14, 2010
My electrolux ambassador power head goes on and off as I try to sweep. What can I do?
Most probably the hose has gone bad. You would new a new one. this will fit your vacuum
http://www.ezvacuum.com/electrolux-hose-with-switch-control-for-electrolux-canister-vacuum-vnotch-generic-p-1525.html
Jan 11, 2013 | Electrolux Vacuums
Following old directions found online I opened an Electrolux Ambassador III to fix the cord winder. When reassembling, I found a loose white wire. Where should it be reconnected?
A white wire is part of the power wiring (neutral), but if the machine runs ok, it may be a left-over from previous work or original manufacturing. If the machine does not run now, then look obvious bare connectors to reinstall it. Hope this helps!
Oct 02, 2010 | Electrolux Vacuums
ElectroLex Cannister model C101J Cord won't retract, trying to remove hard plastc side strips. Appears to be 'one-way' lock in 'T' channel - suggestions unlock?
Use a screwdriver to pry on the top or bottom of REAR cover. I t is held by 4 prongs that fit into 4 holes in tabs. It took a little effort to do mine but it came off. From there you can access retractor mechanism.
Jan 09, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
How do I dismantle an Electrolux Ambassador II?
you don't, as a repairman, even i have a hard time opening them, and then the hardest part is putting it back together.
Sep 14, 2009 | Vacuums
Electrolux Ambassador stainless lower wand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=638738
Posted by Cuyler on Jun 01, 2008
I am trying to locate a stainless lower wand for an Electrolux Ambassador model 1623. The search has proven fruitless so far. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of thought came to mind that you can try. Look in the yellow pages for your local vacuum dealer to see if they carry it to contact your Electrolux factory @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 01, 2008 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Oxygen 3
Most cord reels have a stop on it, it is a rubber wheel and when dust gets on the wheel, they won't always stop the reel. It would have to be opend up to get to the cord reel, then you could clean it out.
Jan 12, 2008 | Electrolux Z5935 Bagged Canister Vacuum
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Lux 5500 Canister Vacuum Logo
520 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Gerry Harvey
Gerry Harvey
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
