When I power up my projector the fan appears to work over time, then slow down and then repeat this process a few times, once it has done this the light switches from flashing green next to the power symbol and turns red on the bulb symbol. It was doing this last week so i bought a new bulb, I've put this new bulb in but it is still doing the same routine...
Try running some white vinegar through it as if you was making coffee (but don't use any coffee) and when done either repeat processes or run a clean pot of water to clean out the vinegar and see if the water is coming out faster. You might need to repeat process a few times. The vinegar breaks down any hard water residue.
Owner's Manual. LCD PROJECTOR. BG630. BG650. Please read the safety ... DivX Video-on-Demand (VOD) movies. ... The product images and On-Screen Display (OSD) in this manual are ..... Turn off power to the lamp and cool down the lamp. ..... 2 After running the WiDi program on your notebook, a list will show all ...
LG ElectronicsGet information on the LG BD630. ... Component Video Out, 1 (Rear) ... on a big screenunder the stars, our home video players give you the ability to do it all. ... you can not only use your home video player to watch movies from a disc, but ... Projectors: Watch movies outdoors, show a photo montage on your living room wall ...Missing: bg650
The issue is the clutch contact inside the projector. The contact is either broken or out of adjustment. The clutch spring protrudes from the hub of the mechanism camstack. The camstack makes ONE revolution for ONE slide cycle. The clutch contact stops the clutch spring at the end of the cycle, putting the projector in "idle", awaiting the next "cycle" signal. Based on your description, this is your problem area. Turn the projector upside down & remove the bottom cover. CAREFULLY remove the internal lenses with a CLEAN, lint-free cloth. Wrap each lens in a separate cloth, as the lenses can shatter if exposed to rapid temperature changes. Next, remove the lamp with another cloth & keep it wrapped, as well. CAREFULLY plug the projector back in (DANGER - EXPOSED VOLTAGE!!) & turn the projector to the "Fan" position. Look for the rotating camstack. Turn the projector on & off quickly to locate the straight wire protruding out of the camstack hub. Turn the projector OFF & UNPLUG. Now look for the "J"-shaped wire that SHOULD make contact with the clutch contact. You will need to re-form the clutch contact wire VERY GENTLY (the wire is brittle!!), so that the straight wire is JUST BARELY trapped by the "J"-shaped wire. Now plug in & turn the power switch to "FAN" to check that the camstack only makes ONE revolution. If it stops: GREAT !! If it still revolves multiple times, repeat the process until the camstack STOPS after ONE cycle. This should resolve your continuous cycle problem. Good Luck !! Jim
PROBLEM: The fan is broken
If any fan in the projector not move, broken, jam, the power light blinking 4 times after few second of power ON
SOLUTION: Remove the filter and then remove the upper cover
check fans and fan connector
if all fans are OK then remove the fan connector and reinstall
fix the cover and power ON projector
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Check the manual if you have it or on line. The symptom you are describing may be a built in warning that your bulb has reache 2700 hours. I think there is a reset process and then at 3000 it goes out.
Spent today reading the manual because I have one and the red lamp light is blinking. I called Panasonic and found out the only place that services these units is in Leawood Kansas USA> The place is called Heartland Services.
