SOURCE: "turn off and on again"
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
SOURCE: Camera
It a lens misalignment try tapping the lens gently in an opposite direction the camera dropped on and that should pop the gear back into place
SOURCE: my camera won't let me take pictures
Does it have a memory card? Try taking that out once ;) If that doesn't work - Come back and we'll try something else!
SOURCE: everytime i open the camera flash the screen
Hi, This erroe is related to optical lens, Actueally the slide motor start malfunctioning of the zoom lens this is why the error shows"turn of the power and on again". The remady of this problem is that you have to replace the optical block assymbly.For this please contact any nearest SONY SERVICE CENTRE or contact any parts store and get the optical blok assy Part No. Description A-1512-913-A LSV-1250A (SERVICE) One more thing to add here that if you want to need replacement of lens block on component level then you must contact SONY SEVICE CENTRE.This will reduce the cost of repair. Thanks for using fixya.
SOURCE: when i turn on the camera the lens wont pop open
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
is your camera battery is in a normal working condition?and whether your camera len is stucked
http://www.digitalcamera-parts.net/
e-mail:[email protected]
