Did you find a solution to this? The same has just happened to me....
Has anyone found a solution to this, I now have the same problem, feels like the handle is broken, like it's not opening it and if I pull it will snap off?
Yes I did find a solution :-)
Get a friend to pull the door open as far as it can go without snapping anything (there should be about a 1mm gap you can see down). There you will see a silver bar if you look closely which is the locking mechanism. Get a screwdriver and bash this quite hard until it budges and the door opens.
Once you have got the door open, you will see a bunch of screws to remove on the door. Remove all of these and buy a new handle http://www.4mysamsung.co.uk/cgi-bin/prod... and replace it.
Extremely simple when you know how! It took me hours to figure this out.
Give me a shout if struggling
the hook needs to be bashed outwards not inwards. hammered in a screwdriver to the top of the door to wedge it open, then used the hammer and screwdriver to hit the hook outwards - it then released.
