Hitachi (GD-S200) (GDS200) DVD Drive Logo
Posted on Dec 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will a HL-DT-ST RW/DVD GCC-4241N OC29 burn DVDs
Anonymous
Level 2:
Novelist:
  • Expert 127 Answers
  • Posted on Dec 14, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
127
Questions
0
Helped
21656
Points
404
Yes, but you will need a program capable of making dvds also, such as PowerDVD or CDCreator. I use CDBurnerXP (don't worry about the name, it works for all Windows OS's) because it's free.
tip
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP Home)
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP) [IDE]
Simple solution:
Situation
There is a yellow exclamation mark for CD/DVD drives in Device Manager. The device status in the properties of the driver might indicate an error code, for example 32, 37, or 39. Or the drive simply does not appear in My Computer or Device Manager.
Solution
To solve the issue, you have to edit the Windows Registry:
Click Start, then Run, type REGEDT32 and click OK.
Locate and then remove the following registry values:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}LowerFilters
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}UpperFilters
Close Registry Editor.
Reboot the system for the changes to take effect.
Note: Some programs are unable to detect the CD/DVD drive after these steps. To solve this, simply re-install the program in question, eg: usually your recording software. Also, in few instances the order in which the programs are (re-)installed can make a difference.
on Sep 12, 2010 • Computers & Internet
What reason:- do not read written cd/dvd bt original cd/dvd can be read Model:- HL-DT-ST RW/DVD GCC-4241N Driver of Lenivo Laptop
- first try to clean the lens (use only a cleaner disk, no other stuff)
- second try to read a cd or dvd written by this unit on LOWEST speed alowed, let's say 24x for cd and no more than 8x for dvd
- if that does not solve the problem, a firmaware update for your drive will fix that
1helpful
Will this cd/dvd unit burn dvds? It's an HL-DT-ST RW/DVD GCC-H23N
no you will needa dvd-rw unit to burn dvd's cd-rw/dvd-rom will not burn a dvd being a dvd-rom
Can I burn a dvd on my hitachi HL-DT-ST RW/DVD GCC-4241N
According to the information I have to hand, Yes, you can burn CD,DVD's with a good drive.
Hope that answers your question.
You need the drivers for it if you haven't already got them.
Visit Hitachi.com
1helpful
3answers
Cd\dvd is corrupted or missing (driver detectiv)
Download microsoft fixit from http://www.ziddu.com/download/6528022/MicrosoftFixit50027.msi.html and install it in your pc ,once its finished jst restart your pc and see it will work
4helpful
2answers
My LG combo drive HL-DT-ST RW/DVD GCC-H23Ndoes not
The lens for reading dvd is busted and needs to be replaced that is why it no longer read dvd.
Burning problems
Windows can only write to CDR disks in its internal drivers, and to burn DVD's requires a 3rd party program such as NERO or NTI.
2answers
Burning problems
What software are you using? You have to use software to burn. Try NERO
3helpful
4answers
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
