Thank you for posting your question here on Fixya.com.
32' round by how deep? Flow rate is how you size a filter so with total gallons you can calculate how many per minute will add up to the whole pool being turned over is 6-8 hours. The pump and filter are then sized for that required flow...Assuming the pool is an above ground ~4' average depth then total gallons would be about 24,000 gallons. For an 8 hour turnover you would need about 50 gallons per minute. The 210T, T for top mount, is designed to handle up to 44 gallons per minute and turn over a 21,000 gallon pool in 8 hours or a 26,000 gallon pool in 10.
What that basically means is that using a 210 on a pool 32 x 4 would be pushing it. It will work but you will end up backwashing more frequently which raises the overall cost of running the pool. If it is not to late a 24" filter would be better; especially if you have periods of time in your pool season where heavy amounts of debris such as pollen get into the water. A 21" filter won't handle any over a normal filtration load.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
