SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
SOURCE: microwave stopped working completely
If you just bought this in August of 2007, then it's under warranty and you should let Magic Chef fix it for free!
For more help from Magic Chef / Ewave : http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Control Panel of Maytag Microwave CMV 1000B doesn't work
You have a failed
membrane keypad.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very
helpful
when troubleshooting & testing.
If you would like to
have us do this repair for you, we do that for $39.95 plus part costs.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
model number) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: microwave comes on by itself in middle of night
We have the same problem - auto turn-on, non-functioning keys...
I called Magic Chef and they gave me another number to call:
1-888-775-0202
I called, told the rep about our possessed microwave, and they said someone will be calling to schedule a repair visit. We bought the microwave around May '08 and it is still under warranty.
Call this number and get it fixed. It is a safety problem and Magic Chef should take care of it for you.
Brian
SOURCE: I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
