Question about Epson Stylus C86 InkJet Printer
Replacing ink cartridges Epson Stylus SX215 - Epson Stylus C86 InkJet Printer
    Habit-Forming:
    New Friend:
  • 143 Answers
Here's a tutorial on how to do it:
Solved Epson printer doesnt recognize Ink Cartridge
Posted on Aug 05, 2018
6ya staff
SOURCE:
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
Anonymous
  • 94 Answers
SOURCE: how do i change my ink cartridge on the epson
Click on the start menu then go to Printer and Faxes. After that go to your default printer Epson SX215 and right click the printer then click properties. Dialogue box was appear click on the maintenance and then click replace cartridge their was a dialogue box will also appear. Just click the next button and read the instruction when you press the Next button. After that open the cover of your printer when the cartridge are at the center that's the time you can change the cartridge. Then close the cover when you're finished to change the cartridge. Then click the next button and so on to finish.
Posted on May 29, 2010
paulywauly
SOURCE: how to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Posted on Jul 19, 2010
Goldi Kunal
  • 187 Answers
SOURCE: How to Change ink cartridge
#1 Wait until you are out of ink. The warning light and ink-low notifications come on well before the ink cartridge is empty, and even if it runs out of ink in the middle of a print, you can replace it then and finish the print with no problem.
#2 Lift the lid of your Epson inkjet printer to expose the ink cartridge replacement button. Make sure you have plenty of light so you can see what you are doing.
#3 Press the ink cartridge replacement button. This will loosen the empty ink cartridges so they can be pulled up and out.
#4 Fill the empty cartridge at an ink-refilling location, or buy a new ink cartridge to replace the empty one.
#5 Insert the new or refilled ink cartridge into the holder with the same orientation as the previous one.
#6 Press the cartridge replacement button to charge the system and close the printer cover. Charging takes about one minute
Thanks
Posted on Sep 30, 2010
tcfloyd
  • 4 Answers
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Posted on Oct 25, 2010
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
How do I change the ink cartridges on an EPSON STYLUS Sx215
Hi joanmcd2, Just go to control panel and go to (printers for xp)/(device and printers win 7) open the properties of the driver and goto Maintenance tab and then click the EPSON Status Monitor button, you will see the ink levels and there will be an option to replace the ink.
for details pls dwonload the Sx215 manual on this link
Aug 05, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer (epson stylus sx215) wont recognize generic ink cartridge
- try to repeat a remove and replace all cartridge. with the careful and pass.
- if it does not changed, try to reinstall driver,s
good luck .......
Jun 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do i change the ink in my epson stylus sx215?
  • Select "menu" and "setup mode"
  • Select "maintenance" and "change ink cartridge"
GOOD DAY
BOBUS
Feb 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have bought epson sx200 ink instead of sx215 will this still work as if not i will have to return it unopened???
Just have a look at the generic cross reference chart for aftermarket ink jet cartridges & you will see the one cartridge suits ten different Epson models
BLACK >>> T0891 Compatible; Ink contents 19ml
Stylus S20, S21, SX100, SX105johncsuk123
Stylus SX200, SX205, SX215
Stylus SX400, SX405, SX415
Jan 07, 2011 | Epson Office Equipment & Supplies
Epson Stylus SX215 the ink cartridge holder won't move into position so I can change a cartridge
its because the ink housing will only aline when the ink is empty its not like any other printer that you can line the housing up. Wait until you run out of ink then lift up the lid and the housing will be alined - its stupid system and epson dont tell you this when you buy the produc
Jan 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to Change ink cartridge on Epson Stylus SX215
Thanks
Sep 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have a new epson SX215 and have lost the manual.I cant figure out how to replace the ink!! Help needed quickly please., Anne Cunningham
Hi Switch on the printer give a print job and open the panel the head comes to the centre and then you can remove.
Jan 29, 2010 | Office Equipment & Supplies
How to change the ink of an epson stylus sx215
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus C86 InkJet Printer Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
