SOURCE: Z4M is printing fine white lines in the barcode
As the label comes out of the printer...it sounds like your printing in picket fence mode (vertical bars). You most likely have 1 or more pixels out on the printhead...try cleaning first...if that fails... you will have to replace the printhead.
SOURCE: Laser does not scan using Internet Explorer
Try starting the ScanWedge prior to opening the Internet explorer browser. ScanWedge can be found under the Applications partition.
SOURCE: Zebra TLP2824 label alignment problem with MYOB Retail Manager
Ensure that the label size in your MYOB and also the printer driver are set to the same as the physical size of your label. Also do a callibration on the printer.
SOURCE: I have a new LS4278. I need to congigure it to read fedex barcode
All you have to do is create a rule to transmit only the 12 digits you want.
You can create a rule with the Programming manual or the 123scan software.
Both of these are available online at support.symbol.com. Here is a short cut:
http://tiny.cc/d400s
if you need additional assistance please let me know - Thank you, Kim Ganoe 800.933.2839 x251
SOURCE: motorola MC5590 is not able to scan barcode
download the datawedge file for the mc55. Its probably not loaded and configured. Once you have this file on the device and you need additional information please let me know
Here is the version 3.1.7
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12465&sliceId=&dialogID=162320658&stateId=1%200%20162316370
[email protected]
