Computers & Internet Logo
Posted on Dec 13, 2010
I need to download vga.dll version 5.01.2600.0000 Find me a site for it.
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Dec 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
1564
Points
24
Goto google.com enter " vga.dll version 5.01.2600.0000" in the search field. Filter it according to your needs.
Give the instruction i already download d3dx9_26.dll and i already download direct x but still did not play help me by practices
If you installed the relevant dll from a 3rd party site, uninstall it. The appropriate dll may be included on the installation disk. If it is not, you will want to install the latest version of DirectX. Sometimes, Microsoft does not number such versions. Regardless, if you do not find it on the installation disk, get the latest DirectX version from the Microsoft site. Choose to install it from SAFE MODE. If this does not work, try uninstalling and reinstalling the game or program. If that does not work, you might try updating the video card drivers. The freeware program Speccy should identify the video card. Usually, you go to the primary device's (laptop manufacturer's) website for driver, rather than using 3rd party driver installers. Note that the most compatible dll version is likely on the installation disk. Any changes in installation may not be recognized or registered until reboot. You can also try directly extracting the d3dx9_26.dll file individually from the latest DirectX package and installing it into your currently used version via Safe Mode.
Where can I get a free download for windows xp 3 ksuser.dll?
The ksuser.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, ksuser.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not download the ksuser.dll DLL file individually from any "DLL download site." There are a number of excellent reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded ksuser.dll from one of those DLL download sites, remove it from wherever you put it and continue with these steps.
1. Restart your computer if you haven't yet.
The ksuser.dll error might be a fluke and a simple restart could clear it up completely.
2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the ksuser.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
3. Assuming the latest DirectX version from Microsoft doesn't fix the ksuser.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
4. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with ksuser.dll and a reinstall could do the trick.
5. Restore the ksuser.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your ksuser.dll error, try extracting the ksuser.dll individually from the DirectX downloadable package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
90helpful
4answers
I need dll-files.com fixer license key
Download link http://downupfiles.com/0s3nt for Dll Files Fixer v3.0.81. incl. Crack by SMT. You don't need any Serial key for register dll files fixer, with this crack Dll Fixer will works like charm.
You may watch video tutorial on this link Dll Files Fixer License Key
2helpful
3answers
Failed to load library d3d9.dil
Try downloading this file: http://www.dll-files.com/dllindex/dll-files.shtml?d3d9 and placing it in your System32 folder located at C:WindowsSystem32
Hopefully this helps
Thank you
Feb 28, 2011 • Skype IM
35helpful
2answers
Download a vga.dll 5.01.2600.0000
http://www.topshareware.com/vga.dll-5.01.2600.0000-video-driver/downloads/1.htm
There you are.
Ddraw.dll not found
Note: If you've already downloaded ddraw.dll from one of those DLL download sites, remove it from wherever you put it and continue with these steps.
    The ddraw.dll error might be a fluke and a simple restart could clear it up completely.
  2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the ddraw.dll not found error.
  3. Assuming the latest DirectX version from Microsoft doesn't fix the ddraw.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
  4. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with ddraw.dll and a reinstall could do the trick.
  5. Restore the ddraw.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your ddraw.dll error, try extracting the ddraw.dll individually from the DirectX downloadable package.
GOOD LUCK AND PLS RATE THIS POST AS FIXYA!!!!!
2answers
I got problem with d3dx9_29dll was not found.anyone could help?
There are quite a few different ways that d3dx9_29.dll errors may show up on your PC. Some of the more common d3dx9_29.dll errors are listed here:
  • "D3DX9_29.DLL Not Found"
  • "File d3dx9_29.dll not found"
  • "Error while starting game executable - couldn't load DLL file d3dx9_29.dll."
  • "D3dx9_29.dll is missing"
  • "D3DX9_29.DLL is missing. Replace D3DX9_29.DLL and try again."
  • "D3dx9_29.dll not found. Reinstalling the application may fix this problem."
  • "Missing component d3dx9_29.dll"
  • "This application failed to start because d3dx9_29.dll was not found!"
D3dx9_29.dll errors usually appear when a software program, most often a game, is started. Occasionally, d3dx9_29.dll errors will display after a game is loaded but right before the game begins. Unlike many other dll errors which can have complicated causes and fixes, d3dx9_29.dll issues are caused in one way or another by a single issue - some kind of problem with Microsoft DirectX. The d3dx9_29.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, d3dx9_29.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not, under any circumstances, download the d3dx9_29.dll DLL file individually from any "DLL download site." There are a number of different reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded d3dx9_29.dll from one of those DLL download sites, remove it from wherever you put it and continue with the following steps.
1. Restart your computer if you haven't yet done so.
The d3dx9_29.dll error might be a fluke or one-time issue and a simple restart could clear it up completely. It's unlikely this will fix the problem, but restarting is always a good first troubleshooting step.
2. Install the latest version of Microsoft DirectX 9. Chances are, upgrading to the latest version of DirectX 9 will fix the d3dx9_29.dll not found error.
Note: Microsoft often releases updates to DirectX 9 without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: Are you a Windows Vista user with DirectX 10? Your game or program may still need DirectX 9 files to run properly so give the installation a try. Don't worry, both versions of DirectX can be run side by side in Windows Vista.
3. Assuming the latest DirectX version from Microsoft doesn't fix the d3dx9_29.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
4. Uninstall the game or software program and then reinstall it again. Something may have happened to the files in the program that work with d3dx9_29.dll and a reinstall could do the trick.
5. Restore the d3dx9_29.dll file from DirectX 9. If the above standard troubleshooting steps haven't worked to solve your d3dx9_29.dll error, try extracting the d3dx9_29.dll individually from the DirectX 9 package.
2helpful
2answers
D3drm.dll promblem
Go to the following site, copy the d3drm.dll and save it to your c:\windows\system32 folder
I WANT TO DOWNLOAD MY VGA.DLL DRIVER\
Hii, you can download all the driver of your Intel motherboard including graphics(VGA) at http://downloadcenter.intel.com/default.aspx?iid=gg_work+home_dowloads# . Go this site and at the left hand side, go to the desktop board and select your exact motherboard model. After selecting the model you just download the driver as per your requirement and install it.
6helpful
2answers
Can not run Unicode version of ATL.DLL on Windows 95.
hi,
http://www.fix-all-dll-errors.com/msoeres.dll/
u can go to this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
Grand Canyon Tech
Grand Canyon Tech
