You need to clear the paper jam. Have you never had a jam before? I suggest that you download the manual http://service.us.panasonic.com/OPERMANPDF/KXFL511.PDF and check the instructions on page 58-60 for how to clear a Jam.
For Panasonic kx-mb2030 turn off printer, unplug printer, take out drum cartridge. check all orifices that take paper and if you see none or have taken sheet out do this: get screwdriver take out screws on the piece that has the teal tabs on both sides and green wire screw, remove top covering. 3 screws in all you'll see more screws take them out and check the big roller (I found a piece of tape melted to it from hitchhiking on a piece of paper) and I'm a novice who's too cheap to call repairman
Starting SP Mode
1. Type the keys as follows:cleare mode button which appers in yellow color and continue the numbers 107
2. Press the cleare button which appers in red color and hold it down until the SP-mode menu is displayed (about 3 seconds) then switch OFF the machine and switch ON this process re-set the code -thanks
1 2 3
4 5 6
7 8 9
0 #
