Question about Gigabyte GA-8I848P-G Motherboard
Cpu fan is running after shutdown gigabyte 848p
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 84 Answers
SOURCE: intel gigabyte
I already know it gigabyte , but what model of motherboard ?
Posted on Jul 19, 2008
mikeywaf
Michael Wafkowski
  • 346 Answers
SOURCE: my cpu fan is not
Hello elscomputers: If you are sure that there is no other issue with the motherboard -- It was working before the CPU Fan/Heatsink stopped working. Other than making sure that it is correctly connected as shown below -- attached to Pin 1 with all three pins connected (not off to the side by one pin), you can assume it's bad (they do wear out). The cost of a new cooler is pretty minimal and I would just replace it.
Good Luck and Thanks for inquiring at Fix Ya.
Mikeywaf
Posted on Mar 22, 2011
Ms-7108v1
1 long beep dram refresh failed
remove everything
JUST INSTALL MIN. RAM, CPU, CPU FAN, POWER CONNECTION, THAN TURN MACHINE ON, IF OK, CONTINUE INSTALLING I DEVICE AT A TIME UNIT YOU IN COUNTER AN ERROR THAN YOU WILL KNOW WHAT IS WRONG.
now a few things to check video card, ram, cpu fan plugged in right area,
you mite want to reset the cmos, by jumping the connectors for few seconds, then turn machine off, remove jumper, than just install cpu and fan, ram, speaker, keyboard, turn on if ok add video card, turn on , if ok, than install hhd, 1 at a time, than restart system if boots ok than move to next device, keep doing this until you installed everything you want or have to have in the system
Jun 07, 2014 | MSI 848p-neo2-v-848p Neo2-v Intel 848p...
Always shutdown"CPU Shutdown Temperature
Hello download a manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=1093
Check the bios for any cpu overclocking settings
and set it back to standard settings.
Renew also the thermal cooling paste between the cpu and the cooling fan.
See if the cpu fan is running when the pc starts.
Be VERY carefull when you remove the cpu cooling fan
and take care not to damage the cpu.
And take antistatic precautions when you work on the mainboard.
If you have not tryed this before let a expert do the job.
Hope this will help you
Nov 22, 2012 | EliteGroup Computer Systems Ecs...
My cpu fan is not working in my Gigabyte GA-8ST667 system can anyone tell me why am sure the cpu fan is good
Mikeywaf
Mar 22, 2011 | Gigabyte GA-8ST667-L Motherboard
Computer turns on but after 1~2 seconds, it goes off again.
Check your smps and then after cpu fan .
If you need more information, reply me soon.
Thanks
Feb 23, 2011 | MSI : 848P Neo-LS Pentium 4 848P 800MHz...
Msi , pc boot , HELLP
Seems like your processor is getting overheated.
Check the heatsink for proper installation, and if possible apply fresh heat release compound.
Also make sure the fan is working and correctly attached.
Please don't forget to rate this answer if it helps.
Jul 23, 2009 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
Cpu fan still running even the system was shutdown
Unplug your computer from the wall socket. Then the only power it will have is the battery that keeps the CMOS information. There will not be enough power for anything to run.
Don't forget to rate this solution.
Jan 19, 2009 | PC Chips P21G (881038000916) Motherboard
Gigabyte GA-7N400 Pro fan makes tick noise after shutdown
i have a tick sound everytime my computer is on use.
Dec 26, 2008 | Gigabyte GA-7N400 Pro Motherboard
Intel gigabyte
Jul 01, 2008 | Intel Motherboard
Intel gigabyte
i want intel 875/865/848p series mtherboard utility...
Apr 20, 2008 | MSI 848P Neo-V Motherboard
Gigabyte GA-8I848P-G Motherboard Logo
167 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Ekse
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
