Cars & Trucks Logo
Posted on Dec 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mercedes benz B-170 after 50 km the code is coming 0793 (a0, 1, 7, 93) please refer to relevant technical manual and code 0722(a0, 1, 7, 22) check by scaner X431 what problem
  • Anonymous Mar 29, 2014
    1100 OR CODE 80 AND 11 CAME UP ON THE SCAN AND SAY REFER TO RELEVANT TECHNICAL MANUAL
Colin Stickland
Level 3:
  • Mercedes-Benz Master 22,516 Answers
  • Posted on Dec 13, 2010
Colin Stickland
Level 3:
Answers
22516
Questions
Helped
6989964
Points
66324
P0793....Intermediate Shaft Speed Sensor Circuit No Signal
P0722....Output Speed Sensor Circuit No Signal
would need a manual to know where these sensors were to be honest
2answers
Can I use lunch x431 to correct error code on Benz s320 c1517
No. you have to correct the bad part. Suspension air pump. bad wiring or plug.
Mercedes benz e 320 1998 model engine light code p0400
code p0400 refers to exhaust gas recirculation(EGR) system---flow malfunction.===causes---hose leak/blockage--basic setting not carried out (if applicable)---wiring---EGR valve ---EGR solenoid---ECM
check out the valve and solenoid.
1helpful
2answers
Can you manuelly check the oil level .
2005 Mercedes Benz C 240 Sedan (203.061) V6-2.6L (112.912) Vehicle Level a_003366.gif Engine, Cooling and Exhaust a_003366.gif Engine a_003366.gif Engine Oil Dip Stick - Dip Stick Tube a_003366.gif Technical Service Bulletins a_003366.gif All Technical Service Bulletins arrow1.gif Engine - Oil Level Message General Information arrow2.gif blnk_spc.gif Engine - Oil Level Message General Information GENERAL INFORMATION ON OIL LEVEL MESSAGE IN INSTRUMENT CLUSTER
Topic Number LI01.45-P-047548 Version 1 Design Group 01.45 Oil Pan Date 08-06-2009 Validity Valid for engines: M111, M112, M113, M166, M266, M271, M272, M273, M275, M285, OM611, OM612, OM613, OM628, OM629, OM640, OM642, OM646, OM647, OM648, OM668 Reason for change Update model designation/Supercedes SI S-B-01.45/26a and S-B-18.00/36a
Reason for block
COMPLAINT:
The attachment to this document contains detailed information on procedures and possible remedies in the event of implausible display messages concerning the engine oil level in the Instrument Cluster (IC).
Specifically, it contains information on:
1. Notes on implausible display messages
2. Overview chart of the relevant switches
3. Supplemental notes on oil level measurement
CAUSE:
For causes of implausible display messages, please refer to the document in the attachment (observe correct language version).
REMEDY:
For procedures and remedies in the event of implausible display messages, please refer to the document in the attachment (observe correct language version).
Engine Oil
Capacity
6helpful
4answers
2helpful
2answers
G224 daimler chryshler gearbox diagram
hello,good day,try to request a cd or manual ( technical support) to your dealer maybe they can provide a photo copy or a cd for your reference,ty
2helpful
Hi, my 1996 mercedes E200 has quite few electrical problems,. scanner pulled out following fault codes: p1584, p1580, p0100, p0130, p0370, p0110.. please help :)
P0100 OBD-II Trouble Code
Technical Description
Mass Air Flow (MAF) Circuit Malfunction
Basically this means that there's a problem with the Mass Air Flow (MAF) sensor or circuit.
You will likely not notice any serious driving problems, but there may be symptoms like a general decrease in power or sluggishness.
Causes
A code P0100 may mean one or more of the following:
* The MAF may be disconnected, or a wiring connection may be bad.
* The MAF sensor may be faulty.
Possible Solutions
Use an OBD II Reader (or go tou your local parts store and they will for free) and reset the code and see if it comes back.
Then start with the cheapest, easiest repair procedures:
* Check the Mass Air Flow Sensor wiring/harness is connected properly and that there are no broken / frayed wires.
* Unplug and reconnect the MAF wiring harness a few times to clear the contacts.
* Check the voltage of the MAF sensor (refer to a repair manual for vehicle specific information).
* Replace the MAF sensor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mercedes Benz E 280 2006 Motor Moaning
hi,for my opinion,your dealer should write a technical product report to main distributor for further evaluation,ty
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
