SOURCE: Viper auto alarm
Check the wiring again, The Ford company uses a light control module in their vehicles. It is fact that the main CPU (Central Processing Unit) stays on line for about 45-60 minutes after the vehicle is shut off that this could show enough of a voltage drop to trigger the alarm when it goes off. If at all possible you may want to monitor the voltage after shutting the truck off and see if the alarm triggers at the same time the voltage drop decreases across the battery after the CPU goes to sleep (45-60 minutes). I hope this helps or at least explains why you may see a foltage draw while testing. Remember to be patient while waiting for the computer to shut down. it will.
Good Luck,
SOURCE: viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
SOURCE: Can you lock the viper 5301 keypad?
Yes.
Press and hold Function (f) for 12 seconds.
Press and hold Lock for 2 seconds
(The keypad will light up)
If the green light by the lock button shows keypad lock on/off (no light).
Press lock- green light comes on.
Press and hold f for 2 seconds
Command entered
Press and hold f or wait 30 seconds for it to time out and the amber light turn off.
