Sony VPL CS5 Multimedia Projector Logo
Posted on Jun 30, 2008
Sony VPL CS5
The projector lamp turns on normally, then a high whine starts and aabout 10 sec's later the lamp shuts off, and the lamp light (yellow) comes on.
Any ideas? I've lost my manual.
  • 1 more comment
  • jemragz Dec 17, 2008
    PROJECTOR TURNS ON FOR TEN SECONDS THEN WHINES AND THEN TURNS OFF.PICTURE IS THERE BEFORE SHUTDOWN AND I CAN FLICK THROUGH MENU. I FOUND LAMP HOURS 2200.I RESET HOURS BUT STILL SAME PROBLEM AND FILTER IS ALSO CLEAN.
  • Sam Jollow
    Sam Jollow Feb 18, 2013
    the lamp is set to high mode you can change this in the menu under the section before the infomation on the menu
  • Sam Jollow
    Sam Jollow May 11, 2013
    you need to replace the lamp
Sam Jollow
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Feb 20, 2013
Sam Jollow
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
8430
Points
23
The lamp mode is set to high to change this go on the menu and goto the image of a projctor and change the lamp mode to low
Anonymous
Level 1:
  • Contributor 36 Answers
  • Posted on Jun 30, 2008
Anonymous
Contributor
Level 1:
Answers
36
Questions
0
Helped
25197
Points
62
You need to clean the filter , the unit is shutting down so it doesnt over heat..look for online manual on how to remove filter and blow off dust.. Good Luck
Sony vpl cs5
Original lamp for cs5 USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
1helpful
I have a sony vpl-cs5 but is not turn in on, some body can help me, have a blinking led that say lap/cover.???
That could indicate the following-
1. The lamp cover or filter cover aren't properly closed. Try shutting the projector down> opening both covers> closing them> restart
2. The lamp is nearing the end of its life or is faulty and you'll need to replace it.
Lamp light on Sony VPL CX4 satys on
Check all In/Out fan and also check is it clean or not
3helpful
2answers
DIRTY LAMP FOR VPL-CS5 SONY PROJECTOR (USED)
to clean the lamp: no chemicals, nothing abrasive. you can touch the outer glass (not with your fingers), but do not touch anythjing inside the bell. best thing to use is a microfiber cloth. your lamp is nearing or has passed 2000 hours of use. the projector is telling you to replace it before it blows (and sometimes shatters). after you replace it, reset the lamp timer (through the menu).
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
4helpful
Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Lamp change
You have to go to the settings on the projector and reset the lamp timer.. Go to your on screen menu and go to settings.. Good Luck
1helpful
2answers
Sony CS5 Wont turn on
the cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
It just wont turn on
Pls open the Lamp unit and check it if it is giving the power indication on the panel.
Viren
2answers
Sony VPL CS5 Multimedia Projector Problem
probably the lamp could be failing
or check the fan'lamp cover switches are being 'made'
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
