Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sounds like Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS].In such cases, the power supply board might need replacement.To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself.If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board.If this is the case, you have to replace the main board.
? 9:47 www.youtube.com/watch?v=zE0eqB4Ppjw Nov 11, 2012 - Uploaded by LUFERQUINT
HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ..
Something short on its main digital board. Contact any service technician. This is not a user repairable fault.
To get more details, http://electronicshelponline.blogspot.com/
You are safe. :) It may have shut off from a voltage spike or brown-out on the line. There are several fuses inside of the TV that are supposed to blow before anything catches fire. If it starts smelling again, then unplug it and take it to a service center.
Unit is telling you something is wrong with circuit. LED pilot flashes when malfunction is detected. Power supply shuts unit down to prevent further damage and/or fire. Leave off and seek pro/tech check out
