You need to replace the gasket in the fill valve if it is a problem that was not there when it was new. If it is new? Check the water flow from the supply line to the toilet. Turn of the water to the toilet, remove water line from toilet, run water into a bucket to check flow. @ the bottom of the fill valve where the water connects, on the inside there may be a screen that in plugged
