Viking 31 in. VGSU101 Gas Cooktop Logo
Posted on Dec 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One burner will not light other burner clicks
espressonist
Level 3:
  • Viking Master 1,711 Answers
  • Posted on Dec 19, 2010
espressonist
Viking Master
Level 3:
Answers
1711
Questions
Helped
651550
Points
5029
Under the burners where you have the gas pipes and valves
you have only one electrical part the ignite spark module. This plastic box has
one input the power wire and for outputs one for each burner. Now you can check
if the wire going to the problematic burner is loose or cut out and fix it. If
all wires look ok then the Spark device is bad and need a new one.
Jenn-Air Dual Fuel Range Model JDT8895BAS
The igniter will click on all the burners simultaneously no matter which burner knob is on. This is normal.
Aug 27, 2014 • Cooktops
Left burner not lighting
Could be the igniter isn't sparking, sometimes they get cracked and run to earth you will still hear it click. Remove the top plate and check the wiring and igniters, turn the lights off and you will see if it's sparking all over the place.
Starter clicks but doesn't light burner
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
When lighting any burner...the igniter continues after lighting."click, click, click, click, click" and so fourth. Thank you for your time.
My parts list doesn't tell me if that is an auto relight unit or not. But since you say it happens on any burner I'll leave out stuck ignitor switch for now.
Check the house ground wire to the unit and check that the burner caps are installed properly. The auto units read a ground when they ignite so if the burner caps are on wrong or dirty they can cause this.
jim
1helpful
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
Burners ignite simultaneously (clicking)
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Ignitor on burner #2 keeps clicking even after burner #1 lights
Jenn Air uses a reignition system on their gas cooktops.It is very important that you have a well grounded recepticle. Please check that and please get back to me.
2helpful
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Top Viking Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
