AEG Master
- Posted on Dec 12, 2010
Re: My AEG competence oven is making a loud buzzing noise...
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Thanks. Had a look at this. It is a long cylinder fan in the top as you have described. Would this buzzing be from it getting jammed? The buzzing sounds like a vibrating noise? it a replacement required?
