How do you delete unwanted PC media files stored from a JVC Everio MG130 Camera? I need to free up some room as I have a number of video shots I would like to delete off my PC hard drive.
Answer:what you do is you press the play/record button on the left side of the camcorder when it is open to get to the videos. then you use the laser touch operation to scroll to the video you want to delete. then, right under the screen there should be 5 buttons. the one to the left of the menu button has a picture of a garbage can looking thing above it. just press that and then press yes when it asks you if your sure.
Deleting unnecessary files on my jvc everio camcorder from my pc
1) on camcorder- connect camcorder to pc via usb
2) on camcorder- open screen and make sure blue button is on video setting
3) on camcorder- select one touch export (screen shows export to library)
4) on PC- select my computer
5) on PC- you should see the EVERIO_HDD show up as removable storage device
6) on pc- double click folder
7) on pc- double click SD_VIDEO
8) on PC- delete the PRGxxx folder of the video you already downloaded
(xxx representing the numbering schema of the folder)
9) on pc- close my computer window
10) on camcorder- power off camcorder.
11) on camcorder- disconnect USB
12) on camcorder- power up camcorder
13) on camcorder- video management error message is displayed on screen
(file is damaged recovery is required/playback recover?
14) on camcorder- select OK
15) on camcorder- recovery complete message on screen
16) on camcorder- select ok
17) on camcorder- damage is fixed and you can use the camcorder again...
this works for me....
Trying to delete unwanted files from everio hard drive that have already been downloaded to computer and put in imac trash. Files are not on the recorder but the memory remains allocated.
We have the same problem withthe Everi Software. We cannot figure out how to delete movie files fromthe computer that have been downloaded to the computer.
Everio HD GZ-MG145A.Cannot delete files stored on PC.What to do?
I also have not been able to delete the files from my computer. I have used up a lot of memory and want to free it up since I have burned the movies on to disks. Please advise.
Yep, got the same problem. I can't delete files off the camera from my PC. Can anyone help? For me, the only solution seems to delete all files from the camcorder itself, and that'll take a long time, I guess?
