My zebra tlp 2844 won't print, i already tried to self test the printer and it print. but when i use my computer it won't print but the feed button light is green. i already re socket everything but still nothing happened.. any ideas? thanks..
check the connection configuration (if is com port, check speed, flow control and others)
Try to install locally with segull drivers (www.seagullscientific.com) if you need, reset to factory defult. print a test label from the driver. if is comunicate, is not printer problem, is connection problem with your software.
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
