The measuring cup you lost is equivalent to 3/4 cup or 180ml and this can make approximately 2 and 1/4 cup of cooked rice. http://
For more details, you can download Owner's Manual at www.rivalproducts.com , You can also inquire on this site about cup replacement.
All right, this can be a bit confusing. IF you still have the cup that came with your Rice Cooker, use it to measure your rice. Then, inside the cooker there are lines showing how much water to add based on how many of the Zojirushi measuring cups you used of rice. THAT's simple.
IF you DON'T still have your Rice Maker measuring cup you will have to use a 3/4 cup U.S measuring cup. This equals the same amount as the rice cooker cup. For each 3/4 cup of rice you use, add that many cups of water. If you use 3/4 cups of rice twice, then add water to the 2 line.
In other words, a rice cooker measuring cup equals 3/4 cup of regular U.S measuring cups.
Hope I didn't confuse this too much. I hope this helps and if it does, please let Fixya know by rating my solution. Good luck and happy cooking!
mcdevito75 here, Most of these cups that come with these machines are measured by the standard 8--10 oz. standard cup. but to be sure here is Saltons contact, email only [email protected]
You use one cup of water for each cup of uncooked rice. You end up with about 2 cups of cooked rice for every cup of uncooked rice. Different varieties, such as brown rice, take more water, up to 2 cups of water per cup of uncooked rice. If the resulting rice is too dry, you can add more water and restart the cooker.
I am not sure, but I believe that 16 cups refers to cooked rice, so you should not put more than 8 cups of uncooked rice in the cooker.
Most of my experience with the rice cookers is that they require a japanese rice Cup which is different than the japanese regular cup. makes a whole lot of not sense but i found a replacement cup at one of the local Japanese Markets if you had to you could use regular measuring cup and use the 160ml for your measure. also the cup has a "Inomata" on it so maybe the web can help you
Eat lots of Rice
