Dry chainbar indicates the oil pipe from the pump/reservoir is blocked. Just needs a clean out. - Oil leaking from bottom after use indicates reservoir is continuing to syphon oil from pipe joints because oil pump is creating pressure in the tank because of blocked pipe. Simple cure is to crack open the oil cap each time you stop using the saw. This will release the tank pressure and stop the syphon effect.
Gunk built up in between bar and saw
