It sounds to me that the pump or pipe is blocked, first check the pipe for any blockage if that is clean remove pump, open it (useually 3 screws) and clean that, if it is clean then your impeller is worn and needs to be replaced. Make sure the pump is running by actually, when pump are open start the machine and check if pump is running, if not check if all electrical wires are connected, also make sure that the opening that feeds the pump in the drum is clean as well
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
