The switch is wired backwards. Swap sides with the wires.
If you look closely at the switch you will see that one side has 2 screws that are joined together with a metal tab. _That_ is the side that gets the hot wire, pick a screw, it doesn't matter which one as long as you don't break off that tab.
On the other side of the switch you will see that the 2 screws are _not_ joined together with a metal tab. _Those_ are the screws that connect to each individual switch leg.
