Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
Posted on Dec 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i remove the pedestal base - Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Anonymous
Level 3:
  • Master 668 Answers
  • Posted on Dec 11, 2010
Anonymous
Master
Level 3:
Answers
668
Questions
Helped
190372
Points
1925
There should be four screws attaching the base plate flange to the back of the set. The flange of the base goes inside the bottom of the set so the screws should be near each other on the lower back. In rare cases I have seen a smaller plastic cover that clips on and off over top of the screws.
I hope this helps,
Skyassoc
How do I remove the TV stand from a Panasonic 50Px80U?
Do you mean the original pedestal base for the Panasonic TH-50PX50U? The base has two vertical posts that fit into recessed areas in the TV. Then four screws (two per post) secure the TV and base together. To remove the base, place the TV screen down on a solid surface that is covered by a clean soft cloth. Remove the black M5x25 screws and slide the base away from the TV. To store the pedestal more easily, remove the 4 silver M5x18 screws that secure the posts to the base. A Philips head screwdriver is needed. Save all of these parts in case you need to put the pedestal base back on the TV.
See page 7 of the Quick Start instructions here: https://pdf.crutchfieldonline.com/ImageBank/v20090127124100/Manuals/133/13350PX80.PDF .
I hope this helps.
1helpful
HOW DO I REMOVE THE PEDESTAL BASE TO WALL MOUNT THIS TV? HAVING LOTS OF TROUBLE! HELP!!
Lay the tv on its face and look at the back of it where the pedestal is attatched,there will be some screws holding the pedestal to the tv. may be on the bottom of some brands.
Remove pedistal base from 24h898 aoc envision tv
You need to remove the cover that hides the 4 screws that hold the stand to the monitor. There are 3 pieces to the pedestal base. The base plate, the pedestal, and the screw cover. To remove the screw cover, look on the back where the pedestal attaches to the monitor. There is a cover just above the pedestal. Pinch the top left and top right sides (about one inch from edge) to unclip the cover. Remove the 4 silver screws (2 on each tab) and put them in a ziploc bag to avoid losing them. Tape them to the pedestal/base and cover.
1helpful
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
28helpful
2answers
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
3helpful
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
3) Remove the five screws shown in the diagram below. This will
4) Once you have removed all five screws holding the pedestal
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
3helpful
How do I remove the pedestal of my Kohler sink?
The pedestal is caulked on top and buttom. remove the caulking you can remove the pedestal. make sure the sink is bolted to the wall, there should be 1 bolt on each side of the sink. (looking from buttom up.)
3helpful
Remove the base of a pedestal sink.
There are two bolts on either side of the sink. Remove them and lift the sink off of the base. Sometimes, depending on who installed it, you can slide the base out without removing the sink. Hope this helps.
Mar 14, 2009 • Home
2answers
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
