Question about Braun Office Equipment & Supplies
Windows 7 does not recognize my just purchased Braun Novoscan I scanner, although print on the set-up cd pretends adequacy for Windows 7. Cannot find in Braun's web how to download controllers needed. Thanks and regards. Jose.
  • Braun Master
  • 6,073 Answers
Which NovaScan product do you have? The one that I know is the Novoscan 4000 which is listed for XP or Vista (32- or 64-bit). Since the drivers do change over time, sometimes the old software doesn't work directly.
The software is here: http://www.braun-phototechnik.de/en/downloads/Software-Treiber/~did.8~nm.15~nc.21/BRAUN-NOVOSCAN.html . Get the correct version for your computer - 32-bit or 64-bit. Unfortunately, I don't see any OS version labels here.
Unfortunately, Microsoft has no information on the compatibility of the Braun NovoScan products. http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?l=en-us&type=Hardware&s=Braun%20NovoScan .
If you continue to have problems, there are two options to try. 1) Install with the compatibility mode. This may work. 2) Install to a virtual computer with an OS that you know is compatible (or a second computer with that OS).
For item 1). Download the software or use the CD. Right click on the exe file and choose Properties. Click on the Compatibility Tab and set it to run as compatible with an older version of Windows. Save the setting by clicking OK. Next right click again on the exe file and choose Run as Administrator.
For option 2) If you have Win7 Pro or Ultimate there is a free option. Download and install Microsoft's Virtual PC and then the XP mode. Otherwise you need a virtual computer program and a licensed version of an older version of XP. Install the scanner inside that "computer". The only issue will be that files can't be shared between the two "machines" directly. You will need to save files to external media (or optical media) to share them. Also peripherals (like printers) can only be installed to one "machine" at a time.
I hope this helps.
(I found some other sites that claimed to have Novoscan drivers but the trustworthiness of those sites are unclear to me. They were found by Google.)
Posted on Dec 12, 2010
Anonymous
SOURCE:
How do I get my HP Pavillion to communicate with my Braun multimac slidescan 6000?
Are you letting windows find it or are you pointing the installation to the cd software disk?
Jan 14, 2015 | HP Office Equipment & Supplies
Plz help to get my scanner work.............. BENQ 5000B Scanner For Windows 7 32-bit
Hi ,
You need to use the install cd that came with your unit but probably it won't run under Windows 7 .
The only work around possible is to install a virtual version of Windows XP on your drive : http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Wish you good luck , otherwise you will need to purchase a compatible unit .
Regards .
Dec 14, 2014 | BenQ Office Equipment & Supplies
Installing hp 1510e, plugged cable, wiil not recognize
then try to install manually, under Windows click add new printer,...
then find your printer on list and choose it.... and install it....
use drivers either to load by Windows automatically, or use path to your CD with software and drivers
Jan 13, 2014 | HP Deskjet 1510E Inkjet Multifunction...
Canon Canoscan LiDE 25 shows "USB device not recognized" on Vista Home Premium 32-bit
Point # 1 : Electronic devices are not made to be used sparingly or stored for long periods of time.
Point # 2 : 5-6 years is not 'barely' in-terms of an electronic device's lifetime (Given that the warranty for your device is about 1 year !).
Point # 3 : You obviously tried almost everything on the computer site of this issue, Its time to take your device to a service center.
Dec 03, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
I just purchased a DELL Inspiron .. running Windows 7. It says if I just plug in my Cannon MX 310 Printer/Fax that Windows will recognize it and set it up for me. I see that it definitely creates an...
I am sure that, you have not installed the drivers of that printer, because Windows 7 recognize most of the printers automatically however the printer and fax machine would start working properly the time you would install the printer drivers on your system and laptop, please let me know it works or not, so i can send you next update on it
Sep 28, 2010 | Canon PIXMA MX310 All-In-One Printer
Purchased new Canon ImageRunner C2550... using as network printer and scanner. 3 computers on network, Canon 2550 recognized two computers no problem... cannot get it to recognize the third one. Third...
The network setting for the scanner driver may be incorrect. Check the IP address of your scanner and then set the IP address on the scanner driver.
1- The steps of setting the IP address may differ depending on your operating system.
For XP operating system:
Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras.
For windows 7 operating system:
Start > Control Panel > ... View scanners and cameras.
2- Right click on the scanner icon for your machine and select Properties.
3- Click Network Setting tab and select Specify your machine by address.
4- Enter the IP Address you confirmed from the snanner menu or ask your network administrator and click OK.
Hope this helps.
Jun 17, 2010 | Canon imageRUNNER C2550 Color Copier
Upgraded to windows 7 and my hp photosmart c6180 is not printing
one option you have is to go to hp/support type in your product c6180 you'll have software download options for windows 7. These downloads should enable your printer to print again. Although from using windows 7 the os has been very good at recognizing printers when plugged in. Could try unplugging and replugging the printer in from the usb. Windows 7 might recognize and automatically download the correct drivers. If not download the software from hp.
Jan 09, 2010 | HP Photosmart C6100 All-In-One Printer
Windows 7 compatibility forthe DPR 1260
My DPR-1260 arrived yesterday and I set it up easily in minutes on both Windows 7 (32-bit Pro) and XP SP3 with 3 printers attached. So far I have only tried wired connection. Wi-fi may be more problematical.
Printers are Brother HL-2040, HL-2140 and Samsung CLP-300. Could not get it to recognize my Canon Lide 25 scanner
Oct 30, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
The Scanner's "Copy" program does not open
Try updateing the software. goto www.canon.com and download up dated drivers for you model.
Feb 15, 2008 | Canon CanoScan 3000ex Flatbed Scanner
1,360 people viewed this question
Top Braun Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
