Posted on Dec 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHEN I TURN IT ON, IT FLASHES THE MESSAGE "PROTECTOR"
Anonymous
Level 3:
  • Master 458 Answers
  • Posted on Dec 11, 2010
Anonymous
Master
Level 3:
Answers
458
Questions
0
Helped
217489
Points
1225
Power output short need replaced
( you can check all speaker and speaker wire )
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Error code 52, Dryer won't start
You have a motor error. Remove any load from dryer and check if drum turns freely by hand. Check L1 power supply voltage, motorwindings, and motor thermal protector (if motor thermal protector has tripped,it may take up to 30 minutes to reset). If error persist, replace the motor with this new one.
Oct 15, 2012 • Dryers
SONY Push Power Protector DAV - DZ610
Shahid, my Sony DAV-576WF is getting push power protector (SD detect), think it might be one channel blown, I do have the Schematic Diagram (service manu book) and ee knowledge with tool, could you give me a hand on fixing that when you got time?
It is no a fancy receiver but it does play SACD/DSD, that's the part I like
my email is [email protected]
Hello, the other night when I was driving home from work, the car radio suddenly turned off and it now will not lock on to any station, sits there a couple of seconds thinking and then a message...
What kind of radio is it? Is it factory, or after market? If it's after market, what is the brand and model number? If it's the factory, what is the make and model is the car?
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
4helpful
I have sony ericsson W100i mobile. Whenever I try to send a message it displays a message " Out of memory delete messages?" However at that instant there are hardly any messages in my inbox, send...
dude this mobile is just a scrap..
i am suffering from day 1 since i have bought this cell phone. There s no solution to this problems. i even installed new OS and S/W from Sony Ericcson service centre. It didn't serve the cause. I am planning to contact directly the manufacturers to get my money back. If u guys have any idea how to do this then pls do mail me to this ID [email protected] r call me at 8867790191
When I turn on my Home Theater Sony Model hcd-hdx576wf this message appears, "protector, push power". what I can do?
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
1. Check the speaker wires and speakers for proper connections.
2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
2helpful
My Sony Audio Reciever will not turn on. The word "Protector" is flashing in the digital window. Can you explain how to reset / troubleshoot?
The output circuit is detecting a short. In order to prevent a fire or prevent any further damage to the amplifier circuit (output) the Protector will prevent the receiver from functioning, thus you have the flashing light. These types of problems usually occur from a damaged output transistor. The only way to repair is to replace the transistor. You can also check the inside for any foreign matter like dirt inside the equipment.
5helpful
HP PSC 2355 does not "boot up".
Is it connected directly to the wall socket for the power supply or thrugh a surge protector.. if its through surge protector try connecting directly to the wall jack ..
3helpful
Protector flashing
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
