Samsung np-q45 cathode backlight not working if you hold screen up to light screen is working just no backlight might it be the circiut borad that controls backlight or the tube has gone and it needs a new screen?????? Thanks Russell
If it's the right-most status indicator on the laptop (a circle with a line through it), blinking means the computer is in Sleep mode. Just move your mouse or hit the enter key and it should wake up.
Hello Your Samsung tV is LCD type. It has no bulb to replace as in DLP projection televisions. there is CCFL [Cold Cathode Flourocent Lamps] are the lighting devices, which are fitted just behind the LCD screen There will be more than 12 numbers of them, accroding to screen size. If these lamps do not light up; that is; if you do not get any backlight with your LCD TV, the backlight inverter board should be troubleshooted. This is the board that supplies high frequency high voltage to these lamps to light up. Check this inverter baord first. Repalcing backlight CCFL lamps is really a skilled work, as they are fitted inside the panel, and to replace them, you have to disassable the panel itself.
The
screen displays becomes dark/ dim if there is no backlight. There
are two parts responsible for lighting the display. First is the CCFL
(Cold Cathode Florecent Lamp), which is the back light and the second
is the Inverter board, which provides high voltage to the CCFL. These parts are inside the LCD screen. Either
of the parts may be faulty or in some rare cases both. So,
my advice is that you get it properly checked by any professional for
replacement of Inverter or CCFL.
the problem of your tv is the backlight...a backlight is a set of cold cathode bulb that is inplace at the top and bottom of your monitor..this light illuminate the screen once this light is busted your screen will go black.this lamp is replasable...you can replace them once they are busted...
hope this could help you..good luck!
your rate is important to this help..pls
Hi, Hold down the Fn key and look at the F keys for a key that looks to have a monitor screen on it, when you find it just tap that key to switch between screens.
This is an known problem I think you must replace the backlight: look for example ebay partnr:
260327530145 only for example if this is your problem.
PRODUCTS ITEMS LCD CCFL BACKLIGHT LAMP IBM THINKPAD T20 T21 14.1" SCREEN LAPTOP & MONITOR LCD SCREEN PROBLEMS SOME COMMON SYMPTOMS FOR BACKLIGHT LAMP REPLACEMENT -Flickering,
red or pinkish hue to display and even total darkness. These symptoms
are a result of a failed or ageing backlight or a failed, damaged. This
is caused by the defective backlight lamp and all you need to do is
replace the backlight. DESCRIPTION Our high brightness LCD cold cathode lamp (CCFL) with
long life, it is more than 50000 hours, with Japanese new cathode,
phosphor, glass, and other materials, they are perfect for all LCD
backlight application and other purpose, such as instrumentation,
medical devices, and all type devices. COMPATIBLE MODELS Suit for Any 14.1” LCD Screen (2.0mm in diameter and 290mm Length) and (2.0mm in diameter and 292mm Length) CUSTOMERSERVICE / CONTACT US Email: [email protected] (12 Hours Response Time)
