Question about John Deere Garden
John Deer F725 won't start - one of the safety switches is prohibiting starting. Battery OK , even tried jump start ...but won't turn over.
  • 124 Answers
My name is Dane and I am going to assist you in solving your problem. However, I would ask that you do one check for me before we go to the seat switch procedure. Please find the starter solenoid on your mower. Make sure that the large cables coming from the battery and going to the starter are clean and tight. Make sure that your 1 (possibly 2) wires going from your switch to your solenoid are also clean and secure. Use a volt meter on DC volts, or a test light and check the small lead on the solenoid and make sure that when the parking brake is on and the Deck PTO is off, that you aren't getting 12VDC when the key switch is turned to the start position. If you have a 2-wire system, 1 of them is for ground only. 1 of the 2 wires should get 12VDC. If you get 12VDC at the small terminal of the solenoid, but no power to your starter, the solenoid is bad.
But you are probably correct that you have a problem with the seat safety switch on your lawn mower. The seat safety switch makes sure that if you are ever thrown from your mower, the engine will die.
You should check under the seat of your mower and locate a small square box with normally 2 wires connected to the end of it. While looking at the switch, press down on the back of your seat and make sure your seat is activating the switch. If not, you must get the switch correctly positioned so it makes contact and pushes the button. If you found nothing wrong there, go to the next step.
Make sure the 2 wires are connected and the wiring is in good shape. Disconnect the wires from the switch and make sure there isn't any corrosion on the terminals of the switch or the connector. After you have done this, reconnect the switch and try again to see if the mower will start.
If not, disconnect the switch again and place a jumper wire between the 2 prongs of the connector and tape them so they will not ground out on the frame. Start your mower and see if it operates correctly. If so, you have got a bad seat safety switch and it needs to be replaced. This was only a troubleshooting procedure. You should never operate a mower with this switch disconnected, because you could be seriously injured. Go buy a new switch and replace it. You will need the make, model and serial number of the mower in order to get parts.
There is a small chance that either your clutch/brake safety switch or your PTO safety switch could also be at fault. Normally they won't go bad, but will just get out of posistion so that when you activate the clutch/brake they won
Posted on Dec 11, 2010
  • Dane Beckett
    Dane Beckett Dec 11, 2010
    Sometimes the clutch/brake won't engauge the switch. Just look at it and make sure it does. Need any more help, just let us know.. Thanks! Dane
6ya staff
SOURCE:
I have a john deere f725 i replaced ignition module but still no spark on either side what do i try next?
un plug the coil and see if it will start. if it does might be a safety switch bad.
Nov 06, 2016 | John Deere Garden
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
I need a diagram that shows me how to replace the belt on my F725 front deck john deer mower
hi there pauly46 here
type f725 in the search box - under j/d cataloue
here is web site adress to go to that page
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?search=model&model=f725
select f725 ,select sectional index , select mower deck and lift linkage,select mower drive belts sheaves and spindles ,
then a window with deck parts and diagram will appear
print this off
it will give a good idea of belt routing for deck
take a look and hope it helps
cheers pauly46
Apr 29, 2011 | John Deere Seat For F710 F725 F735 Riding...
Ridding mower lt 133 willl not start
The wireing to the relay,battery power to pin 30.Purple wire should be on pin 87.Other purple wire that gets power from the safety swutches has power to it only if all the safeties are in place ,pin 86.Pin 85 is a ground wire.If the park brake is on and the pto is off and you are sitting on the seat then it should start.If it does'nt the you need a key switch,a starter relay,or as starter.
Jun 12, 2010 | John Deere Lawn Tractor Seat F710 F725...
Garden Logo
2,246 people viewed this question
Top John Deere Garden Experts
Dave
Joseph Mueller
Joseph Mueller
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
