I WOULD SAY NO ! THE PICTURE TUBE IS PROBABLY AS MUCH AS THE TV IS WORTH. i had a very nice sony trinatron tv. the picture tube whent on it at about 5 years so I CALLED FOR REPAIR AND THE PICTURE TUBE WAS 2-300 DOLLARS. good-day !
Hi.. Most manufacturers offer a 1-year warranty on equipment. If the Tv is less than a year old, I would recommend contacting the retail outlet you purchased the Tv from and have them arrange a repair from the manufacturer, with no cost to you.
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Is it only the input that has the direct tv connected to it that has no
picture, or do you have no picture at all on any inputs? If you are
able to watch a dvd on say AV1 or input 1 but have no picture on the
other input that has the direct tv box connected to it I would call
direct tv and have them look at your box. If you have no picture at all
then it is your tv. and it being 10 years old it is almost a natural
failure a strange occurrence that being it happen right after you got satellite.
Sounds like the back light is out, and the unit needs servicing. You can check this by shining a flashlight close to the surface, and if some image is seen, the the back light is the cause. Else the LCD driver is gone.
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at. Thank you all for you time. JC
Since it is 5 years old mostly dry soldered appears. First sort out the soldered problem. Then check zener diode in video input path is short. Mostly the diode is short. Still get problem check video switching ic also. I think former is the most problem.
